It is currently Tue Nov 18, 2025 1:48 am
PostPosted: Sat Sep 27, 2014 8:34 am
Hello,
I am considering getting an electric Fuel pump now for Ruster.
I am having issues on load with the mechanical pump and the vacuum pump pulling crankcase vacuum.
this is for a carbuerated Setup and I think 7-9 PSI is all that's needed.
What do you recommend?
Do I need to get a separate fuel pressure regulator also?
Thanks for the Help.
PostPosted: Sat Sep 27, 2014 4:00 pm
I ran a simple Summit racing pump on my bogger..(750cfm) with no regulator (Rochester carb) and had excellent results.....
...however...it was dead in the box when I got it because of machining bits in the case. I took it apart and cleaned it out...ran for years.
It replaced a Carter I had for 35 years....cheap simple.
PostPosted: Sat Sep 27, 2014 7:05 pm
Car Model: Toad Wagon
I've been using this Mr. Gasket model in my Toad, my HAMBster, and 4 of'em in our Rose Parade float, for over eight years now.
All also use a Holley regulator, to about 3 psi, perhaps not needed for your application.
Early on I had trouble with a couple of'em getting gummed up, 'til I switched to Chevron exclusively on all of'em.
No problems since.
Yes, Kiddies, the Chevron comment/fix is patently subjective.
Still, I'd not mention it if I thought it irrelevant, so take it for what it's worth to you.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sat Sep 27, 2014 7:36 pm
I'm running a Bosch 044 and i am happy with it other than the fact it is loud. I was running an Aeromotive fuel pump and it had a serious cavitation issue.
I am running about 50 psi and have throttle body fuel injection.
These ones go to eleven...
PostPosted: Sun Sep 28, 2014 4:56 pm
Holley blue pump and regulator, set at 6 psi.
PostPosted: Sun Sep 28, 2014 5:49 pm
SSRN National Champion
Holly blue for gas and black for alky always worked good for me without a problem. In my experience I found its better to spend a few bucks extra and get a good regulator the first time. You want it to be dependable and hold consistent fuel pressure.
PostPosted: Sun Sep 28, 2014 9:01 pm
Holley Red pump is an internal bypass that works with carbs. For extra protection I installed a secondary regulator. Been on there for several years with zero problems.
It sounds like you have a weed-eater in the trunk through the firewall. (Unless you have upholstery, then you might not notice it.)
On the bright side, when it goes silent, your out of gas! :lol:
PostPosted: Sun Sep 28, 2014 9:56 pm
:lol:
Dick, 225% crazy.
PostPosted: Mon Sep 29, 2014 5:26 am
Thanks Guys.
Should the Regulator be mounted near the Pump or Near the Carb?
PostPosted: Mon Sep 29, 2014 6:50 am
Underhood where convenient to get to.
PostPosted: Wed Oct 15, 2014 9:20 am
I run an in tank aeromotive stealth 340lph with 3/8" feed to a aeromotive rising rate fuel pressure regulator to a 1/2" return, all going to a Holley 650dp mod'd for blow through, haven't ran out of pump yet lol
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Wed Oct 22, 2014 5:34 pm
Holley red pump has been and still is on the red Dart for better than 10 years. Regulator set at 4.5# as Carter/Edelbrock is not fond of pressure above 6#.On the street 64 Dart I run a Jegs/Holley as a backup for the stock pump.It is used mostly for HOT starts/vapor lock for our 100 + degrees summer weather.I also ran Carter Street pump on my Big Block cars as a pusher from tank to stock mechanical pump.
