Wheel size for 63 Valiant. (Disk Brake Swap)
https://mail.slantsix.org/forum/viewtopic.php?t=4720
Author:  killin5 [ Mon Dec 30, 2002 1:02 pm ]
Post subject:  Wheel size for 63 Valiant. (Disk Brake Swap)
I am planning a disk brake conversion for my 63 Valiant.
I will be changing the bolt pattern from the small to the large bolt pattern.
I know that I need at least 14 or 15 inch wheels to clear the disk brake calipers.
I would like to use a stock steel rim, preferably 15 inch, with a tire that has an aspect ratio of 60.
What I am wondering is how big (Wide) of a rim can I get onto the rear of a 63. I’m not as much worried about clearance once everything is bolted up, but about being able to physically get the wheel in there. Will a 6 inch rim be safe, or can I go a bit larger with a 6.5 or 7?
I’m not planning anything too wild here. This is for a street car.
Can anyone give their opinion from practical use here?
Thanks,
John Killin
Author:  james longhurst [ Mon Dec 30, 2002 3:47 pm ]
john,
i just went out and looked at my two '63 convertibles. one a valiant, the other a dart. the signet has sbp 14" wheels off a '73 duster and 205/75-14s in the rear and clear everythig ok. the dart on the other hand has 15x7 cop wheels with 245/60-15s and just barely clear the wheelwell and leaf spring. up front are 205/60-15s with identical wheels and i recall some clearance problems around turns. the dart has large bolt discs and 8 1/4 axle from a '75 dart parts car if that matters.
the wheel wells appear to be similar though the sheetmetal is a tad different but i think the 15x7 cop wheels would fit the valiant. i have no idea what the backspacing is and i think more clearance could be had with a smaller tire like say 225s or something.
hope this helps.
-james
Author:  bud L. [ Mon Dec 30, 2002 3:57 pm ]
Post subject:  jacking
Of course you'll only be able to put one rear tire on at a time, jacking under one of the frt spring perch 'box' areas at a time.
Author:  kesteb [ Mon Jan 06, 2003 12:16 pm ]
On my '65 Dart I currently have 15x6.5" rims with a 225/60 tires. They fit without any problems. These are plain steel rims from a Dodge van. I am going to go to 15x7" rims with 235/60 tires. All indicataions are they will clear just fine. These rims are from a Cordoba.
Author:  Matt Cramer [ Mon Jan 06, 2003 5:03 pm ]
Post subject:  Large wheels
My '66 Dart has 225/50R16 tires on 16"x7" wheels all around, with 3/4" backspacing. I need spacers in the back, and I had to roll the inner fender lip up front, but they fit with no trouble otherwise.
Author:  james longhurst [ Fri Jan 10, 2003 3:56 pm ]
hey matt-
any pics of your '66? hey, that sorta rhymes... uh, anyway, what sort of wheels are you running? what backspacing, etc? i would like to make an upgrade someday and am curious. thanks!
-james
Author:  Dart270 [ Sat Jan 11, 2003 1:43 pm ]
Stock Mopar 15X7s should be fine with 215/60s or so, but may need some fender trimming with 225/60s or bigger (from '80s 5th ave or Diplomat at junkyard - maybe trucks too?). I have 16X8s on my '64 Dart with 245/45ZR16s and there is plenty of room with a small front lower fender trim. I ran the Mopar 15X7s with 225/50s and no fender trimming - fit fine.
For my current setup, see: http://www.slantsix.org/galleries/richm ... dracer.jpg
Cheers,
Author:  Matt Cramer [ Sun Jan 12, 2003 10:47 am ]
I meant 3/4" offset, not backspacing (it would look really weired with 3/4" of backspacing!). The backspacing is 4.25". The wheels are American Racing Spinnakers. A little heavier than Center Lines, but cheaper. Here's a picture of it from the front, before I'd switched the rear to large bolt pattern:
<img src="http://home.cwru.edu/~mac9/Spinnaker1.jpg" width=544 height=334>
