wheel cylinder replacement
https://mail.slantsix.org/forum/viewtopic.php?t=4736
Author:  Duster Driver [ Wed Jan 01, 2003 11:08 pm ]
Post subject:  wheel cylinder replacement
My left rear wheel cylinder is leaking fluid and needs to be replaced. Can the wheel cylinder be replaced without having to take off the brake shoe? In the manual that I have it talks about different special tools that are used to remove the brake shoe. Do you really need these special tools?
Author:  alienduster [ Sat Jan 04, 2003 10:33 pm ]
Kinda yes, kinda no. You definitely have to remove the uppoer springs and spring/pivot pin in the middle of each shoe. you can then leave them hanging there and will have anough room at the top to remove the cylinder.
Author:  Matt Cramer [ Mon Jan 06, 2003 4:58 pm ]
Post subject:  Special tools?
What special tools? :D I've replaced brake shoes and cylinders using just a needle nose pliers, a regular pliers, and a socket wrench.
Author:  Plymouth Duster72 [ Wed Feb 05, 2003 5:02 pm ]
No special tools required...granted, it may be easier with the proper tools but you can remove the shoes with simple hand tools from around the house.
-Don
Author:  dgc333 [ Thu Feb 06, 2003 4:28 am ]
You can purchase the proper brake pliers for around $10 and another 3 or 4 for the cup tool. For the number of times you will do brake jobs paying for a Snap-On set is just not warranted.
The pliers especailly make the job so much easier I would consider it a mandatory tool in your box.
