| 9" Brakes tight fit https://mail.slantsix.org/forum/viewtopic.php?t=4758 |
| Author: | slanted 67 [ Mon Jan 06, 2003 8:20 pm ] |
| Post subject: | 9" Brakes tight fit |
Is this correct? |
| Author: | killin5 [ Tue Jan 07, 2003 5:40 am ] |
I rebuilt the front drums on my 63 Valiant last year. I had a similar problem with the pads I got from Autozone. They had given me the only set they had available for my 63. I had them pull out a box for either a 61 or 62 valiant and the pads were noticeably smaller. I bought this set and everything went together perfectly. John Killin |
| Author: | kesteb [ Tue Jan 07, 2003 3:12 pm ] |
When properly adjusted, there should be a slight drag on drum brakes. |
| Author: | slanted 67 [ Thu Jan 09, 2003 10:39 pm ] |
I can barley turn the drum by hand. Although I know when I drive, my brakes are working, and there is not excessive drag that can be felt. I can still push the car by hand on a level surface. I guess I don't have anything to worry about. Any comments are appreciated. |
| Author: | Dart270 [ Fri Jan 10, 2003 6:41 am ] |
If you can push the car by hand w/o trouble, I think you're fine. Lou |
| Author: | slanted 67 [ Sun Jan 12, 2003 5:38 pm ] |
Thanks for your help!! I am kicking myself on this one!! I discovered that I installed the adjuster lower than where it should have been installed and caused the brake pads to be about a 1/8 inch out more than necessary. When I corrected the error the hub went on as it should, with slight friction. Thanks again!! Great website!! |
| Author: | bud L. [ Sun Jan 12, 2003 10:51 pm ] |
| Post subject: | yup |
This is why you do one side at a time, so you can readily check your work. |
