| After market water temp guage question https://mail.slantsix.org/forum/viewtopic.php?t=49356 |
| Author: | Turbo Toad [ Thu Jul 19, 2012 10:20 pm ] |
| Post subject: | After market water temp guage question |
I was wanting to install a autometer temp guage with a thermal couple and was wondering where or if any members have Installed one in there slant pics would be every helpful Thanks. Org [/quote] |
| Author: | Romeo Furio [ Fri Jul 20, 2012 4:03 pm ] |
I will look for pics if I have any, I drilled and tapped the head at the thermostat area to install the probe. |
| Author: | Doc [ Fri Jul 20, 2012 4:07 pm ] |
I usually install the fitting in the thermostat cover. Off-set it to the outlet side to avoid contact with the "peak" of the thermostat, under the cover. DD ![]()
| Author: | Turbo Toad [ Sun Jul 22, 2012 1:13 am ] |
Doc did you just drill and tap the thermostat housing or did you have to brazen it I like the idea it seems simple enuff Thanks any more options Aaron |
| Author: | Greg Ondayko [ Sun Jul 22, 2012 4:21 am ] |
I installed one on my race engine using the old heater hose nipple on the head. I removed the heater hose nipple and installed the adapter to the thermocouple that leads to the mechanical gauge. Here are a few shots - Scroll Down to Post Named 3-30-10 Engine in and Runing! If you still use the heater on your car a pipe T could work for this.. Greg |
| Author: | Turbo Toad [ Sun Jul 22, 2012 8:13 am ] |
Greg that's a great idea thanks I already have a couple tees and some ball valves for my heater hoses too the water inlet on my Clifford intake I don't no why I didn't think about it Thanks everybody Aaron |
| Author: | coconuteater64 [ Sun Jul 22, 2012 12:25 pm ] |
I teed into the Heater hose at the engine |
