| Smoking regulators https://mail.slantsix.org/forum/viewtopic.php?t=4964 |
| Author: | slanted 67 [ Sat Feb 08, 2003 9:58 am ] |
| Post subject: | Smoking regulators |
I "smoked" my second voltage regulator. When I turn on the ignition my regulator fries. This is the second one that I destroyed. I have checked the manuals and cannot find the reason. i think it has something to do with the resistance or wiring. Does anyone know where to start. |
| Author: | /6demon [ Sat Feb 08, 2003 11:26 am ] |
the only voltage to it should be the wire from the ballast resistor thats spliced into the "I" wire of reg.........i'd have to guess either 1 of the 2 field wires is shorted or a problem internally with the alternator. |
| Author: | slanted 67 [ Sun Feb 09, 2003 12:37 pm ] |
Guess that was the cause. |
| Author: | Pierre [ Sun Feb 09, 2003 7:17 pm ] |
| Post subject: | Regulator shmegulator |
Try a one wire style alternator... you pull the plug on the original regulator, run a single wire from the alternator to the battery, and voila no worries. Been running a powermaster 200A one wire with no issues. |
