Looking For A Phsyco Six...
https://mail.slantsix.org/forum/viewtopic.php?t=4983
Author:  BLEBYU [ Mon Feb 10, 2003 9:23 am ]
Post subject:  Looking For A Phsyco Six...
I am getting closer to needing a engine for my six project and I would like buy an engine that is complete, and one that is proven to be fast. Anybody got a wild one for sale?
Thanks In advance
Author:  Doc [ Mon Feb 10, 2003 3:01 pm ]
How fast is your idea of fast??
Do you want torque or RPM?
What is your budget?
Where are you located??
Author:  Guest [ Tue Feb 11, 2003 5:13 am ]
Post subject:  How Fast...
Well I live about 20 miles from Dale Rose in Ga so my idea of fast is 9.90s!!!! I want to buy or build a nos motor. If I have to go from scratch I was thinking 3.5 inch bore, light crank, aluminum main caps, aluminum rods, biggest valves, best cam, ect, an planned to spray the $*%@ out of it! My car should be light around 2200#, But i know there are not many of this type engine out there so I would take somthing less to get started and get the car sorted out any ideas?
Thanks, Mike
Author:  60Pioneer [ Tue Feb 11, 2003 9:35 am ]
I just ran some quick numbers on an internet "Racing Calculator" If you're going to run 9.90's with a 2200# car you're looking at 450+ hp. If the weight is closer to 1500# you can do it with about 300 hp. Just talking off the cuff, but lowering the weight and hp may be a little more realistic. In the mid 80's I had a 69 Camaro Super Gas car, Alston Chassis (tube frame) , 9" Ford, 4 link, 496 BB, Powerglide, 2200 lbs. It ran 9.90's.
Author:  Doctor Dodge [ Tue Feb 11, 2003 10:24 pm ]
Go grab any 68-75 SL6 (forged crank engine) do a 'quickie' overhaul and add some cam.
Get the head checked for cracks then do some clean-up work the ports and install some oversize valves. Toss a good intake and set of headers on it and go racing.
I did this a while back, used a junkyard SL6 short block and ran 14.5s, hit it with some spray and went 13.09 before I fried it.
Author:  60Pioneer [ Wed Feb 12, 2003 6:43 am ]
I'm with you, Doc. 2200#/13.09 puts you at 195+ at the rear wheels. VERY do-able.
Author:  Doc [ Wed Feb 12, 2003 8:54 am ]
Yup, junkyard shortblock race engines are pretty common, especially in "claimer" type racing.
Run the numbers based on 2800 lbs, that's what my Barracuda weighs.
Author:  60Pioneer [ Wed Feb 12, 2003 10:19 am ]
http://www.turbofast.com.au/Drag.html
I should have posted this before, sorry. Here's a link to the calculator I've been playing with. :) And Doc, that puts your Barracuda at acout 250+ at the rear wheels. That's some serious hp for a /!
Author:  Charrlie_S [ Sat Feb 15, 2003 7:58 am ]
How about a streetable 170 engine at 3215 lbs? 13.22 sec 1/4 mile. Nitrous fogger system, on a very mild engine.
