| Removing oil pan https://mail.slantsix.org/forum/viewtopic.php?t=5022 |
| Author: | Jopapa [ Mon Feb 17, 2003 2:37 pm ] |
| Post subject: | Removing oil pan |
Will I have to lift the engine at all in order to pull the oil pan off a 225 in a Dart Swinger? |
| Author: | Doc [ Mon Feb 17, 2003 3:27 pm ] |
You will have to lift the engine and get the steering center link out of the way, the best / easy way to do that is to drop the idler arm and turn the wheels full right. Take a measurment off the oil pick-up to the block's pan rail, so you have a reference to reposition it upon reinstall. (after cleaning) DD |
| Author: | Jopapa [ Mon Feb 17, 2003 4:52 pm ] |
Any way I can support it without needing a hoist (which I don't have)? For measuring the oil pickup, you mean for reinstalling that, or the pan? I had figured it was seperate from the oil pan itself. |
| Author: | Doctor Dodge [ Mon Feb 17, 2003 7:11 pm ] |
You can use a floor jack from underneath, then use blocks to hold the engine up. For the pick-up tube, you want to get it back to the same height / position in the pan so find a way to do that. Measure or make a template to go by, you don't want to have to take the pan on and off a bunch of times to set the pick-up so it hugs the floor of the oil pan. DD |
| Author: | Jopapa [ Mon Feb 17, 2003 7:49 pm ] |
Quote: You can use a floor jack from underneath, then use blocks to hold the engine up.
Oh I getcha. Didn't realize the hight could be changed.For the pick-up tube, you want to get it back to the same height / position in the pan so find a way to do that. Measure or make a template to go by, you don't want to have to take the pan on and off a bunch of times to set the pick-up so it hugs the floor of the oil pan. DD So if I jack up the engine and put say a piece of 4x4 lumber in where the engine mounts go, should I be fine? |
