It is currently Mon Nov 17, 2025 12:29 pm
PostPosted: Sun Oct 14, 2012 7:03 pm
June 10, 2010:
An update to modifications made to my 225, 67 Dart rag top:
Oversized ENDG valves, ported, gasket matched, and shaved 0.075â€￾ calculated 9.5:1 compression peanut head.
Clifford intake & shorty headers, Holley 390 4V carburetor.
Dual exhaust.
Bored over 0.030â€￾ block.
Unknown hot cam that loves 3000 to 5000 rpm.
Orange box, blaster II coil.
904 driven by a 2600 (on paper) stall converter. (Seams to lock up @2200)
3.55:1 8 ¾â€￾ Suregrip, D70/14 T/A’s.
Haven’t weighed the car, but is most likely on the heavy side north of 3100 pounds (+ 220# for me) because of; HD suspension, anti sway bar, sub frame connectors, 8 3/4â€￾ rear, and sound deadening on floor. Nor has it seen a dyno, so I don’t know what the torque, and power curves look like.
[img]http://i294.photobucket.com/albums/mm87/wjajr/1967%20Dart/100_0682-1.jpg[/img]
All runs made at Winterport Dragway’s 1/8th mile track, elevation ~160 ft.
_____________________________________
June 12, 2010:
Shift automatically in D @ 4000 rpm.
Run 1
Reaction time = 1.165 sec.
660’ - 10.752 sec @ 62.15 mph.
Run 2
Reaction time = 0.973
660’ – 10.752 sec @ 63.47 mph.
Oct. 2, 2010
Shift @ 5000
Run 1
Reaction time = 1.134 sec.
660’ – 10.67 @ 64.56 mph
Jan 2011
Degreed “Mysteryâ€￾ cam
Lift at valve Exh= 0.460â€￾; I = 0.444â€￾
211 degree center line Exh @ 113 degrees, I @ 99degrees
Exh @ 0.050â€￾ = 236* I @ 0.050â€￾ = 235*
Overlap @ 0.050â€￾ = 23*
Summer 2012
Installed o2 sensor.
Tuned carburetor jetting etc., discovered secondary’s were not operational, and corrected that problem. Car became a lot more responsive.
Oct. 13, 2012
6000 rpm shift
One run
Reaction; a comatose 1.229 sec.
60 foot @ 2.336 sec.
660 ft. @ 6.736 sec.
67.95 mph.
660 ft. @ 10.352 sec.
Finish line was reached while still in second gear below 6000 rpm
So long story short comparing Oct. 2010 outing with today’s
60’ shaved 0.072 seconds
660’ shaved 0.196 seconds
3.39 mph faster
1/8th mile: shaved off from June 2010 first run; 0.400 seconds to date.
________________________________________
This winter: more compression to be added.
