| Six Gun https://mail.slantsix.org/forum/viewtopic.php?t=50369 |
| Author: | SIX GUN [ Mon Nov 19, 2012 3:35 pm ] |
| Post subject: | Six Gun |
Destroked 300 (272ci) FORD I-6 10.96@121 with 55mm side draft webers http://imageshack.us/a/img186/5978/picscarstuff007.jpg 11.14@118 with 650DP on HOLMAN/MOODY intake http://imageshack.us/a/img717/2892/6339527.jpg |
| Author: | Fopar [ Mon Nov 19, 2012 3:43 pm ] |
Very impressive! Richard |
| Author: | Slanteast [ Wed Nov 28, 2012 5:59 am ] |
Very impressive indeed...tell us more about your combination. Weight, gears,trans etc. What rpm do you launch at? Any inline stick shift is inspiring in my books, nice car! Derek |
| Author: | SIX GUN [ Thu Nov 29, 2012 9:21 am ] |
Engine: Destroked 300(272 CID) Pistons: Wiseco .060 over Rods: 6.980" Fowler aluminum Crank: Factory steel, destroked to 3.500" Cam: Racer Brown .700 lift Ignition: Vertex Magneto Induction: (3) 55MM Weber side drafts on a Clifford intake Exhaust: Home made 6 into 1, 1-3/4" primary tube Best ET: 10.96@120 HP: about 420 Weight: 2800 lbs. Trans: Jerico 4 speed Rear end: 9" Ford 5.43 gear I launch @ 7000 shift @ 7000 go threw @ 7300!! |
| Author: | Rob Simmons [ Thu Nov 29, 2012 11:31 am ] |
Schweeeet! |
| Author: | Exner Geek [ Sun Dec 02, 2012 4:43 pm ] |
Wondering why you destroked it. |
| Author: | SIX GUN [ Mon Dec 03, 2012 10:48 am ] |
SOME VIDEO http://img26.imageshack.us/img26/9264/carstuffii008.mp4 http://img51.imageshack.us/img51/1264/c ... iii006.mp4 http://img830.imageshack.us/img830/9554 ... iii008.mp4 |
| Author: | SIX GUN [ Mon Dec 03, 2012 10:59 am ] |
Exner Geek: I DESTROKED it because of (((VIBRATION))) problems when I went to a stick.. With the stock stroke it would shake the flywheel bolt out... |
| Author: | Mroldfart2u [ Tue Dec 04, 2012 5:46 am ] |
WOW.... Impressive, and the sound of a stick car being rowed thru the gears is great.... |
