Cam grind for boost?
https://mail.slantsix.org/forum/viewtopic.php?t=51969
Page 1 of 1
Author:  RyGuyTooDry [ Sun May 05, 2013 6:56 pm ]
Post subject:  Cam grind for boost?
Engine is a 1965 225. Basically stock except for a super six manifold and a 350 cfm holley. Turbo is a TD04. Anyone have a good cam grind for this setup? It'll be between 10-12 psi. Daily driven, so I wouldn't want something too lumpy.
Author:  Jerame_c [ Sun May 05, 2013 9:58 pm ]
I'm working on turboing mine right now. The advice i have gotten from my turbo friends is that low overlap cams work well, something like an RV cam grind. I am just using my stock cam until I have driven it under boost for a while then i can decide better where to fine tune from there.
Author:  Ssg Pohlman [ Mon May 06, 2013 4:02 am ]
My advice would be to cruies over to the FAQ in the boost section that I built. I will cover about every question you can come up with. For short, a lot of people will recommend the stock cam. Shaker223 ran sub 12s with all stock and 340 springs.
Author:  Shaker223 [ Mon May 06, 2013 10:23 am ]
Actually, it was high 11s but with alot more boost than you are planning. A stock cam will make plenty of power. Spring upgrades are needed. Just watch the backpressure.
Author:  RyGuyTooDry [ Mon May 06, 2013 10:37 am ]
So 340 springs would work fine? And also, do you think with headwork (engine builder valves and port job) at 10-12# could get me into mid 12's? 2900# car, 2.76 gears, rebuilt 225/904, td04, super six mani, holley 350cfm.
Author:  Shaker223 [ Mon May 06, 2013 12:49 pm ]
Shimmed 340 springs would work...IIRC 120# on the seat. You should be able to get into the 12's with the mods listed.
Author:  RyGuyTooDry [ Mon May 06, 2013 6:43 pm ]
Alright, thanks! I'll let you know how it works out.
