| Secret Audio Stereo https://mail.slantsix.org/forum/viewtopic.php?t=5211 |
| Author: | jamchico [ Thu Mar 13, 2003 5:10 pm ] |
| Post subject: | Secret Audio Stereo |
Thanks Allen |
| Author: | Pierre [ Thu Mar 13, 2003 7:20 pm ] |
| Post subject: | car audio |
How much are you looking to spend? That is the first thing you should decide, then from there you can get an idea of what best you can get for your budget. Check out www.adireaudio.com their stuff is highly acclaimed. That stuff is best bang for the buck, and most often best bang too. |
| Author: | Guest [ Thu Mar 13, 2003 8:15 pm ] |
This seems to be the only alternative to cutting my dash. I'm hoping it will discourage theft, keep my "look" classic, and provide me with stereo/cd option. So if anyone is using this product I'd like a hands on evalutation. Thanks Allen |
| Author: | Pierre [ Thu Mar 13, 2003 9:09 pm ] |
| Post subject: | whoopsy |
Sorry, I didn't realize that is a retail product, I thought you wanted to do your own stealth installation. Heres an idea for you, you can install it in your glovebox (might need to cutout the back because radio is probably longer then glove is). Then you can control it from drivers seat with an infrared remote. Most decent decks these days come with infra-red remotes. If you feel like being spendy, I recall once year one could take your original radio, replace the guts with modern electronics and add cd, etc.. but it was costly, above $1000 I recall. Not sure if this service is offered. |
| Author: | jamchico [ Fri Mar 14, 2003 6:20 am ] |
I considered the glove. The problem for me is 1: I would have to leave the glove box door hanging open while I'm using the remote,or 2: I would have to cut the glovebox door to put in access for the remote. Also either way I lose the use of the big ol' glovebox:( Allen |
| Author: | slantlover [ Fri Mar 14, 2003 11:58 am ] |
Not sure what model car you have. But I have often considered building a console that would transition from under the dash (tons of room) to the floor. It could be carpeted to match, there could be black plexiglass covers over stereo components, and there should even be room for a couple of front speakers. Stock radio stays where it is, dash is unmolested, and if you want to return to stock, take out the whole thing. Also, it would be safer since it is centrally located and easier to reach. Slantlover |
| Author: | SlantedSix225 [ Sat Mar 15, 2003 5:54 am ] |
If you don't like the idea of leaving the glove box open to use the remote, how about going with a Blaupunkt head unit? Most of them come with an infrared eye about the size of a dime that is on an extended wire that plugs into the back, as well as the standard eye on the face so you can use a thumb type steering wheel control. That is what I used in my 63 Valiant, my install is designed to look "old school," although it's definitely not stock! Check out my site. Dan M.http://hometown.aol.com/Slantedsix225/s ... ix225.html |
| Author: | Guest [ Sat Mar 15, 2003 9:36 am ] |
| Post subject: | Secret Stereo |
Thanks Allen |
| Author: | SlantedSix225 [ Sun Mar 16, 2003 7:47 am ] |
Freak Dan M. |
| Author: | jamchico [ Sun Mar 16, 2003 8:52 am ] |
Thanks for your help Allen |
| Author: | SlantedSix225 [ Mon Mar 17, 2003 5:50 am ] |
Allen, In the paper I tried to explain what you should be trying to do, and suggested ways to do it. It covers the basics of system design from a "deck & four" (head unit and four speakers) through amplified systems and wiring tips for older cars. Not a lot about sub box design, but a pretty good explanation of why to have them. That paper will be next. Feel free to ask any questions. Check your email for the attachment Dan M. |
| Author: | SlantedSix225 [ Mon Mar 17, 2003 6:09 am ] |
Allen, I had another thought, rather than cutting your glove box, you could just mount the Blaupunkt under the drivers seat. With the remote IR eye on the dash, the only time you really need to get to it is to change disks. You could even add a changer, plenty of room under there! Dan M. |
| Author: | Chuck [ Sun Apr 13, 2003 12:29 am ] |
Dan, If you send me a copy of that article, I will try to convert it to HTML and post it in the Articles section. |
| Author: | SlantedSix225 [ Sun Apr 13, 2003 8:41 am ] |
| Post subject: | Article coming soon |
Chuck, I'm in the process of rewriting the article with a few updates. I also took the time to learn HTML, something I've wanted to do for a long time. I'm including a section on sub box construction, and tips on fiberglass fabrication. My schedule is kind of tight right now, but I should have it done in a week or two. Dan M. |
