| Lexan side windows without upper frame..? https://mail.slantsix.org/forum/viewtopic.php?t=52225 |
| Author: | Rob Simmons [ Thu May 30, 2013 12:47 pm ] |
| Post subject: | Lexan side windows without upper frame..? |
Any sages out there with experience in mounting lexan side windows in cars without the upper window frame? (like a Duster I'm looking for a light, but sturdy way to keep the lexan stable. Something that looks decent too. |
| Author: | Tom Drake [ Thu May 30, 2013 1:42 pm ] |
![]() Small tube frame that mounts to the top of the door and bolts the lexan to it. The challenger probably has this in it.... |
| Author: | Tom Drake [ Thu May 30, 2013 1:47 pm ] |
![]() Here is RJ's window kit. You have to bend and weld it up (or have someone local do it.) http://www.rjracecars.com/Window-Frame- ... dview.html |
| Author: | Rob Simmons [ Thu May 30, 2013 1:57 pm ] |
Thanks Tom. The top of the doors have been cut out, so there isn't a good way to use a kit like that. Someone mentioned using brake line bent to the right shape, but that doesn't seem sturdy enough. Especially since the window has a slight bend to it. I may re-use the flat steel that was in there before for now. |
| Author: | Tom Drake [ Thu May 30, 2013 2:10 pm ] |
Does not matter if the top of the door is cut out or not...attach it inside the shell somewhere(only needs two) and bend to match the contour of the door. Easiest, lightest and sturdest way to do it. |
| Author: | DusterIdiot [ Thu May 30, 2013 3:19 pm ] |
| Post subject: | How about? |
How about using some 1/2" electrical conduit bent at the correct angle, and cut long enough to use a set of pipe clamps to screw it or pop rivet it to the door/frame/skin? -D.Idiot |
