Mr. Duster Goes Racing
https://mail.slantsix.org/forum/viewtopic.php?t=5296
Page 1 of 1
Author:  GunPilot [ Fri Mar 21, 2003 9:45 pm ]
Post subject:  Mr. Duster Goes Racing
My first time at the track, and probably Mr. Duster's first time too.
Mr Duster is a bone-stock 1974 Duster that I purchased for $325 from a local. Everything on the car was original, and worked when I got it, including the 8-track.
The rear 7 1/4 died very soon, and I swapped in an 8 3/4 out of a Challenger. I replaced all the front bushings, ball joints, and tie rod ends with Moog rubber replacements.
I swapped in a Super Six setup using all stock parts and a Carter BBD off my 318 pickup. Ran so much better after that.
Rebuilt the distributor and recurved it (took out heavy spring) and set timing at 35* BTDC.
New plugs, cap, rotor, wires, pickup coil, reluctor, ECU, coil, ballast.
Summary of equipment:
1974 Duster 225 /6
Engine: all stock
Timing: 35* BTDC with heavy spring removed
Intake: Super 6
Exhaust: Stock
Trans: Stock 904
Rear axle: 8 3/4, 3:55 gear.
Tires: 205/60/R15 Capital V-rated.
First ever time slip:
R/T: .126
60': 2.801
330: 8.066
1/8: 12.458
MPH: 56.02
1000: 16.275
1/4: 19.536
MPH: 69.13
I made 5 passes.
Best ET: 19.440
Best R/T: .010
Best 60': 2.770
Best MPH: 69.32.
RPM at the 1/4 was about 3500 after a 2-3 shift at 3900 or so.
The tech guys were amazed at the leaning tower of power.
<img src = "http://www.autoinsanity.com/Duster/raci ... "width=400>
On the go. Beat him off the line but slower again.
Edit: One thing I forgot to add in the specs is I'm running an electric fan setup instead of a mechanical fan.
http://ramchargercentral.com/boards/ind ... show;id=19
