It is currently Tue Nov 18, 2025 1:36 pm
 Post subject: Carter Ball & Ball??
PostPosted: Sat Dec 28, 2013 1:56 am
I want to turbocharge my 225 on a low budget. I have a 1BBl carter, is it even possible to use it and pressurize it?
Thanks
Valiant -65
PostPosted: Sat Dec 28, 2013 3:43 pm
Welcome.
To answer it is but not practical.
There is a turbo/boost FAQ that I built that will give you a few days of reading. It will bring you up to speed quick. Just take it in steps as it gets to be a bit much after a while.
If you do decide to boost, make sure to start a thread with your build progress.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
