| Truck wont start https://mail.slantsix.org/forum/viewtopic.php?t=5340 |
| Author: | pickupman [ Thu Mar 27, 2003 10:24 pm ] |
| Post subject: | Truck wont start |
Any help will greatly appreciated! Sorry for the long post. Steve |
| Author: | pickupman [ Fri Mar 28, 2003 6:52 am ] |
| Post subject: | more info |
The battery is holding a charge and everything works except the blower motor and the starter wont make a sound when I turn the key to Start but I do hear a click when I turn the key to the ON position.When I turn the key to the ON position the AMP guage shows just a slight discharge and does't move when I turn it to Start. Steve |
| Author: | Pierre [ Fri Mar 28, 2003 12:13 pm ] |
| Post subject: | a quick test... |
Leave the key in the On position but not cranking, then go to your starter relay under the hood. Get a screwdriver, and short out the two biggest studs... the starter should start going. If it does, the problem is in back of the relay... if it doesn't check wiring to the starter and/or try swapping starter with a spare |
| Author: | pickupman [ Mon Mar 31, 2003 10:11 am ] |
| Post subject: | truck wont start |
My question is what would cause the blower motor and starter to both quit at the same time when every thing else works? Steve |
| Author: | pickupman [ Mon Mar 31, 2003 11:16 am ] |
| Author: | cycledog [ Mon Mar 31, 2003 1:09 pm ] |
I dont know if this will help, but the same thing happened to my 77 truck. It turned out to be the volt meter. Unless they changed this almost all electric power goes through the meter. Good luck and happy hunting. |
| Author: | Slant Cecil [ Mon Mar 31, 2003 1:51 pm ] |
A '77 truck didn't have a volt meter, they still used an amp gauge. Cecil |
| Author: | cycledog [ Mon Mar 31, 2003 3:49 pm ] |
I stand corrected, its monday, I dont think I was awake..... |
| Author: | pickupman [ Wed Apr 02, 2003 4:16 pm ] |
Steve |
| Author: | Doc [ Wed Apr 02, 2003 5:30 pm ] |
At this point it could be machanical damage or a short, you are doing the right thing by checking with a volt meter and jumping around things to isolate the problem. DD |
| Author: | Super6 [ Fri Apr 04, 2003 2:52 pm ] |
If the yellow wire from the ign switch does not have power when the key is in the start/crank position the switch is bad. (The yellow wire activates the starter relay) -Aaron |
| Author: | pickupman [ Tue Apr 08, 2003 8:34 pm ] |
Steve |
