| turbo oil feed https://mail.slantsix.org/forum/viewtopic.php?t=53729 |
| Author: | Junior [ Wed Oct 30, 2013 8:44 pm ] |
| Post subject: | turbo oil feed |
would there be any problem using brake line as an oil feed? my turbo has a restriction in it smaller than the opening in the brake line so i dont think flow should be a problem. what is everyone else using? |
| Author: | Shaker223 [ Thu Oct 31, 2013 5:56 am ] |
No problem with that. I used an AN-4 line because it was easy to route and connect |
| Author: | billdedman [ Thu Oct 31, 2013 11:03 am ] |
I just put a "tee" in at the filter fitting, measured the distance from the oil filter, back to the firewall, across to the driver's side inner-fender panel and went forward to the turbo oil inlet. Then, I went to an auto-supply store and got a pre-cut, pre-flared piece of brake hose that length and bolted it on... Took all of 20-minutes... A piece of cake~ Good luck! Smile Bill, in Conway, Arkansas |
| Author: | pishta [ Thu Oct 31, 2013 12:56 pm ] |
Yup, same as Bill but i went motor route: T at sender, up to valve cover rail forward using that bendable anchor thingy, around front of valve cover to turbo. Use a tube bender and it looks like it belonged their. I went cheap and used an old trans cooler line, cut end and used a short piece of hose to connect to turbo inlet. You can press in a carb jet into the rubber hose as a restrictor if turbo doesnt have one. something like .75-1 lpm. |
| Author: | Junior [ Thu Oct 31, 2013 2:04 pm ] |
sweet. thanks for the replies. i have about 30 inches of 4an braided line that i was gonna use and use the brake line to make up the difference. |
