Oil filter relocation options
https://mail.slantsix.org/forum/viewtopic.php?t=54151
Page 1 of 1
Author:  Greg Ondayko [ Thu Dec 26, 2013 3:04 pm ]
Post subject:  Oil filter relocation options
hello, I am beginning to gather parts for switching ruster to an external belt drive oil pump system..
the oil pump is a single stage external.. no dry sump system.
since I am ditching ole ma mopar's combined Oilmpump and filter I will be going with some sort of remote filter location.
the question I have is: what are the pros and cons of a single filter unit?
what about a double filter unit? (besides more cost and weight)
thanks,
Author:  emsvitil [ Thu Dec 26, 2013 10:24 pm ]
A single filter should be fine.
Also, the stock filter you're using is the same one that the remote filters use, so your stock of oil filters is still good.
With my Toyota truck, I put one of those thermostatic adaptors with an oil cooler in too....
Author:  Ssg Pohlman [ Fri Dec 27, 2013 10:22 am ]
I wouldn't worry about a dual filter setup, just more filters to change etc.
It is true that it's the same oil filters, I believe 3/4 x 18 thread. Basically same filter as the slant, Toyota 22r/re, 80's mustang 5.0, and more. Wix 51515 is a good filter and holds almost a qt by itself.
I've been running a remote oil filter on my / truck for a couple years w out a problem.
Author:  Team Green [ Fri Dec 27, 2013 2:50 pm ]
We run Oberg filters on both cars and have never had a problem with them. Just clean an reuse the screen. It's a one time purchase.
I changed the oiling system on the Lancer to where the Oberg screen is in the top of the oil tank. I will weigh the filter assembly and let you know the weight.
Mark
Author:  Greg Ondayko [ Fri Dec 27, 2013 6:18 pm ]
Mark
Great, Thank you much.. It looks alot Lighter than a cartridge Filter to Me.
Will they work on the wet sump system?
Author:  Team Green [ Sat Dec 28, 2013 9:19 am ]
The Oberg I have is a model 600. It's old and has two 90 degree aluminum fittings attached. It weighs in at 4lbs. 15.8ozs.
Don't see why it shouldn't work with a single stage oil pump as it is one line in and one line out.
Mark
Author:  Greg Ondayko [ Sat Dec 28, 2013 9:32 am ]
Mark
excellent thanks for the info.. I think that is the way to go.. what micron filter do you run on that 6" unit?
Author:  Rick Covalt [ Sat Dec 28, 2013 6:02 pm ]
Looks like their finest screen is 28 microns. The Wix/Napa Gold has a micron rating of 21.
Author:  madmax/6 [ Sat Jan 25, 2014 2:56 pm ]
my filter still mounts in the orig location on a stock aluminum houseing I modified.
Hose goes to adapter between filter and filter holder.
