| 904 rebuild, should I go LU or non-LU ? https://mail.slantsix.org/forum/viewtopic.php?t=54172 |
| Author: | slanty6 [ Sat Dec 28, 2013 8:39 am ] |
| Post subject: | 904 rebuild, should I go LU or non-LU ? |
Trans in my daily driver is in need of rebuild. It is a 1975 Dodge Coronet 4D, approx 3780 lbs. Rear end ratio is 2.94 and tire size is 225/70/15's. I have a stock 1977-78 904 LU w/torque converter and the shift correction kit for it. The car will be seeing some towing use. Reccomendations ? |
| Author: | bigslant6fan [ Sat Dec 28, 2013 8:53 pm ] |
| Post subject: | . |
If it is a 1977 model year trans, it will be non-lock-up,if 1978,it will be the worst trans (my opinion) ever made. Can you find any # on the drivers side of the oil pan rail? |
| Author: | slanty6 [ Tue Dec 31, 2013 11:19 am ] |
I believe it's a 1979 LU 904 trans. part number is 4130413. |
| Author: | bigslant6fan [ Wed Jan 01, 2014 9:46 pm ] |
| Post subject: | . |
My parts manuals list it as a "79 LU too.Pay close attention to the pump clearances,0.001 taller pump rotors can be ordered. The sealing rings on the input shaft, and purchase a new torque converter. Also be carefull not to mix up the springs in the valve body, several of them look very similar. Check my post called "disection of a '78 trans" for more info. |
| Author: | slanty6 [ Fri Jan 03, 2014 10:16 am ] |
Thanks for your input !! |
