| SlantSixDan's 'Souper Flush' & Frantz Oil Filterator... https://mail.slantsix.org/forum/viewtopic.php?t=54684 |
Page 1 of 2 |
| Author: | DCello [ Sat Feb 22, 2014 9:04 am ] |
| Post subject: | SlantSixDan's 'Souper Flush' & Frantz Oil Filterator... |
Hi Everybody - Warm as he&& here west of D.C. and I should be out tinkering with the truck - but first, enjoyed reading all about Lorrie Van Haulin & the Frantz Oil Cleanerator... So I replied to that post but realized it'd be hard to notice and this question really is a new topic - Could the Frantz Reservoir be fitted with a sawed off TP filter cartridge leaving room for CRUD during different phases of SSD's Souper Flush? DCello (I'll be offline for a while out in the good weather) Post subject: (Thu Jan 20, 2005 11:25 am) Reply with quote FrankRaso wrote: I may even treat it to an engine flush Careful-careful-careful. Those "engine flush" compounds you can find at the auto parts store can do a tremendous amount of damage. I have long maintained that your engine is not a toilet (Chevrolet Vega, Cadillac HT4100 and V8-6-4, and Ford 3.0 owners excepted) and therefore does not need flushing except under specific and rare conditions as a corrective measure. Everyone's got a pet theory on how best to flush a crudded-up engine without pulling the pan. Some methods are harmless but ineffective. Some methods are potentially harmful. Some methods are harmless and effective. For best results, pick one of that last kind. I do not believe there is any such thing as a safe, effective and fast engine flush procedure. You can pick any two of these three: Safe and effective (but not fast), safe and fast (but not effective), effective and fast (but not safe). The risks fall into two categories: Softening/damaging engine gaskets and seals so they don't seal well any more Sweeping large amounts of dirt and crud from its resting place into the oil filter, which plugs and goes into bypass mode, sending the cräp directly to the bearings and quickly failing the engine. I watched this happen to a Chev 305 once. It was quite a spectacle. Those "5-minute engine flush" compounds mostly contain Butyl Cellosolve, which is a specialized solvent that's very good at one particular task: Cleaning the mayonnaise out of a crankcase that's had coolant in it due to a faulty head (etc.) gasket. Their use in any other situation is risky. My own engine flush recipe is a delicious blend of Marvel Mystery Oil (very light weight and good at dissolving gums and sludges), Kroil (best penetrant on the planet), ATF (detergent/dispersant with good lubricity), and Berryman B12 ChemTool (good at dissolving crud too tough for Marvel Mystery Oil). My procedure involves warming up the engine, draining the oil, changing the oil filter, replacing the drain plug (!), and pouring in the soup. For a 5-quart crankcase, I usually start with 1/1/2/1 (Marvel/Kroil/ATF/B12). Then start and run the engine in the driveway at around 1200 to 1700 RPM with no sudden acceleration and no load applied, for 15 minutes. Shut down, drain (really let it drain, walk away for 45 minutes), change the filter again, repeat with new soup for 30 to 45 minutes depending how gross the first batch of soup was when it was drained and how quickly the second batch of soup cruds up. Check the dipstick periodically. If the 2nd batch of soup comes out coalmine black and full of chunks, run in another batch of soup (and another new filter!) and repeat until chips, chunks and tar stop coming out when you drain it. You'll note the filter is replaced before any attempt is made to introduce a flushing agent into the crankcase, and the filter is replaced again every time you drain a batch of flushing soup. Without doing this, you run the very real risk of inundating the filter, which will go into bypass mode and send all the loosened-up crud directly to the bearings and other critical parts: Goodbye, engine, it was nice gnawing you. I've gotten amazing amounts of corruption and trash out of engines using this recipe and method. Other methods and other recipes may work better for other people with other cars. And as always, be advised that if the engine is really tired and whipped, even a safe flush can cause additional problems in the form of "new" leaks. |
| Author: | SlantSteve [ Sat Feb 22, 2014 5:25 pm ] |
Personally,I am VERY wary of using this system as the sole means of filtration. From what I could see on their website the system is plumbed into the oil gallery via a small restrictor,so it doesn't bleed too much oil pressure from the engine,the oil then passes through the TP "filter" then drains back into the sump via a return line. So really,it will only filter SOME of the oil AFTER it has passed through the normal filter,so it's really only going to pick up the smaller contaminants,in my opinion its not really a big help in your situation. From what I can gather JC has somehow set his system up as a sole means of filtration,no normal full flow type filter at all.....I can only assume is it still filters some of the oil,but not all that goes to the engine since it's physically incapable of supplying full flow oil supply. To each their own I guess. Have a look at Aggressive teds posts,he has successfully cleaned a few high mileage engines with very good results,maybe compare his "recipe" to dans and see which one works for you. All the best,Steve |
| Author: | SlantSixDan [ Sat Feb 22, 2014 10:26 pm ] |
| Post subject: | I heard my name |
If you are thoughtless enough to fall for the bogus nonsense and handwaving used to promote the toilet paper "oil cleaner", the resultant destruction of your engine is well deserved. Over 'n' out. |
| Author: | JCAllison [ Sun Feb 23, 2014 5:09 am ] |
| Post subject: | Re: I heard my name |
Quote: If you are thoughtless enough to fall for the bogus nonsense and handwaving used to promote the toilet paper "oil cleaner", the resultant destruction of your engine is well deserved.
Hey Daniel, Over 'n' out. At almost 300,000 miles on Ms. American, and almost 200,000 miles on Lorrie, when would YOU estimate that I should expect the resultant destruction of these Engines to happen? I want to be there to see it happen! Have you seen the JPGs that I posted of the FOCS and how clean the oil and Valve Trains are? They don't look to be in any imminent danger of well deserved destruction, do they? Maybe I'll have to wait another 300,000 miles? Anyway, go ahead and spend your money on NEW Oil and NEW Filters even though the innards of your engines still get mucky. BTW, I want to thank you again for the Bendix Stromberg Model W Carburetor. It is working well, and is without a doubt the spiffiest Carburetor that Lorrie has ever had. Lorrie is one happy camper. Your friend, JC |
| Author: | wjajr [ Sun Feb 23, 2014 6:09 am ] |
Hummmm. Considering what that tissue is designed for when applied to the human body it easy to see why it keeps the same organic waste from building up in an engine… This 2 cents is just a satirical observation not an endorsement. |
| Author: | JCAllison [ Sun Feb 23, 2014 8:17 am ] |
Quote: Hummmm. Considering what that tissue is designed for when applied to the human body it easy to see why it keeps the same organic waste from building up in an engine… This 2 cents is just a satirical observation not an endorsement.
Hey Mr. W,Actually, it isn't what the paper was designed to do that is the factor. It's the AMOUNT of paper that is the main factor. Compare the amount of filtration of a mass of paper the size of a roll of Bathroom Tissue to the amount of filtration of a single sheet of paper such as is found in a regular pleated oil filter and it should easily be obvious that the more paper there is, the greater the filtration power. There is another aspect of this: One can obtain a roll of paper to be used as an element in the FOCS that was specifically designed to be used as a FOCS Filter Element. It ISN'T toilet paper! It is a roll of Oil Filter Paper. It costs more than a roll of Bathroom Tissue and doesn't do anything more than a roll of Bathroom Tissue, BUT, for those who just can't, (for whatever reason) countenance using Bathroom Tissue, the roll of oil filter paper specifically designed to filter Oil would be the solution. Still, the caveat about the FOCS leading to the destruction of an engine is particularly ludicrous in light of the longevity of both Ms. American's and Lorrie's Engines. If using a FOCS will destroy an Engine, they both would have most certainly demised by now, if you get my drift. Maybe Daniel could explain WHY neither Ms. American's or Lorrie's Engines have suffered the destruction that he so direly warned of seeing as to how they both are still in fine operating condition. Daniel? Would you care to weigh in on this? Probably not (sigh). Anyway, everyone has a right to their opinion, right? JC |
| Author: | sandy in BC [ Sun Feb 23, 2014 8:24 am ] |
When I was a kid.....(mid 60s) I had a boss who ran a fleet of Ford flatheads running the same Fratzalator Filtration system. My job was dismantling and cleaning 8BA flatheads for "rebuild". They were utilized in 3 ton trucks and beat unmercifully. Those motors were full of sludge and reeked of bad oil. The bearings were pitted and pistons scuffed. The sludge in the bottom of the pans was full of bits of fibre from cheap toilette paper. Watson's (boss) personal "motorhome" was a Diamond T breadvan with a Merc flathead in it. It got good oil...changed regularly and had a decent aftermarket filtration system. He drove that thing to California and back several times a year. It was clean as a whistle. Thats where I learned to change oil and good filters regularly. One summer I helped him install an Olds V8 and Hydro into a 56 chev 4x4 panel......but thats another story. Watson drove a Model C Hal sprint car in the late 30s.....thats a whole book. He showed me the pics.... |
| Author: | JCAllison [ Sun Feb 23, 2014 10:19 am ] |
Quote: When I was a kid.....(mid 60s) I had a boss who ran a fleet of Ford flatheads running the same Fratzalator Filtration system. My job was dismantling and cleaning 8BA flatheads for "rebuild". They were utilized in 3 ton trucks and beat unmercifully. Those motors were full of sludge and reeked of bad oil. The bearings were pitted and pistons scuffed. The sludge in the bottom of the pans was full of bits of fibre from cheap toilette paper.
Hey Mr. SIBC,Well, you see? There was his problem. He should have been running a Frantz Oil Cleaner System instead of a Fratzalator Filtration System. AND he should have been using facial-quality, two-ply tissue instead of cheap toilette paper. The 3.14 and Lorrie have NEVER had a problem with sludge, pits, scuffs or bits of fiber (or anything else other than the carbon that settled out of Lorrie's Oil from sitting for sixteen years) in their Oil Pans. Quote: Watson's (boss) personal "motorhome" was a Diamond T breadvan with a Merc flathead in it. It got good oil...changed regularly and had a decent aftermarket filtration system. He drove that thing to California and back several times a year. It was clean as a whistle. That's where I learned to change oil and good filters regularly. One summer I helped him install an Olds V8 and Hydro into a 56 chev 4x4 panel......but that's another story. Watson drove a Model C Hal sprint car in the late 30s.....that's a whole book. He showed me the pics....
If you don't have a Frantz Oil Cleaner System, it's a good idea to change oil and use good filters.JC |
| Author: | SlantSteve [ Sun Feb 23, 2014 10:55 am ] |
200000 and 300000 miles?? I thought you said the slant was only low mileage from rebuild? 17000 or 25000 miles seems to pop into my mind as figures you mentioned in older posts? The FE engine was rebuilt as well,didn't you mention an old timer ex Holman Moody builder was talking about bearing setup when he rebuilt it? |
| Author: | sandy in BC [ Sun Feb 23, 2014 11:43 am ] |
Its easy to let the facts get in the way of a good story...... JC.....its your truck...you get to believe whatever you want. Lets just say my experience (and others) will prevent me from taking the same path.....................................................2 ply facial quality or not. |
| Author: | SlantSteve [ Sun Feb 23, 2014 12:05 pm ] |
Quote: Its easy to let the facts get in the way of a good story......
Well said.
| Author: | JCAllison [ Sun Feb 23, 2014 2:11 pm ] |
Quote: 200000 and 300000 miles??
Hey Mr. SS,Let's start with Ms. American 3.14159's P Code FE Engine: My father put a Frantz Oil Cleaner System on it as soon as he got it in March of 1964. He was a Frantz Distributor/Dealer. So it has had one of the FOCS units on it for fifty years. The Odometer is presently sitting a 98,872 on the third time around. That would mean that it has gone 298,872 miles, and the old Gal is just 1,168 from 300,000 miles. Her engine was rebuilt in 1988 with the Odometer sitting at 67,599 miles on the second time around, which would have been 167,699 miles. I saw it hit 99,999.9 and turn over to 00,000.0 when it reached 200,000.0 miles. It is now less than 2,000 miles away from turning over again which will be 300,000 miles. Quote: I thought you said the slant was only low mileage from rebuild?17000 or 25000 miles seems to pop into my mind as figures you mentioned in older posts?
YES.Lorrie's Odometer is presently sitting at 28,905. This is on the NEW Stewart Warner Speedometer that was put in at the same time that her mighty 225 Slant Six Engine was rebuilt. in 1985. The OLD stock Speedometer is sitting here on the shelf and it shows 94,373.3 miles on the Odometer. But remember, Lorrie was gotten in 1975 when she was eight years old and she had been used for delivering mail in the Houston, Texas area. It was right after she came to live with me that my father put the Frantz Oil Cleaner System on her, so she has had the FOCS on her Engine for thirty-nine years So if we add 94,373.3 (OLD Odometer) and 28,905 (NEW Odometer), you get 123,278.3 miles. BUT... that's if the OLD stock Odometer is still on it's first time around. I personally have surmised that the 94,373.3 was the SECOND time around which would have added another 100,000.0 miles to the total, making it 223,278.3 miles. I don't recall how many miles Lorrie had on her Odometer when I got her, but if we take the mileage that was on her OLD Odometer in 1986 when her Slant Six Engine was rebuilt (94,373.3) and divide it by 9 (that was how old she was when her Engine was rebuilt) that would mean that she had been driven about 10,485 miles a year, or about 874 miles a month, or almost 30 miles per day. I'll bet her daily mail route was MORE than thirty miles. So if we add 100,000 miles to the amount on the OLD Odometer (surmising that it was on the second time around), it would be 194,373.3, divided by 9 (her age at rebuild), and that would give a mileage of about 21,600 a year, or about 1,800 miles a month, or about 60 miles a day. Which seems more reasonable to me. Quote: The FE engine was rebuilt as well,
YES, at 167,599 miles. Quote: didn't you mention an old timer ex Holman Moody builder was talking about bearing setup when he rebuilt it?
YES. That was Howard Williams, the uncle of Ernie Lozano, owner of Ernie's Motors in Houston, Texas where I rebuilt the Engine.Howard mentored me during the rebuild. He sat in a lawn-chair in his nephew's garage and supervised the rebuild while I did all the actual physical work. He had been a Holman Moody line chief when he was younger. That was a fun time back in 1988. While Ms. American was being worked on, I was using Lorrie Van Haul as my daily driver. Anyway, how is your weather down under? Haven't seen any reports that it is still unusually hot. The weather here has been in the mid 70s recently. Nice weather, though it is overcast most of the time. Hope you are enduring. Take excellent care. JC |
| Author: | JCAllison [ Sun Feb 23, 2014 2:43 pm ] |
Quote: It's easy to let the facts get in the way of a good story......
Hey Mr. SIBC,I am chuckling. Quote: JC.....it's your truck...you get to believe whatever you want.
I know that Sandy. I was more just wanting to share my experience with you all, and not so much trying to convince anyone of anything. Quote: Let's just say my experience (and others) will prevent me from taking the same path.....................................................2 ply facial quality or not.
I completely understand that things that are out of the ordinary (like the Frantz Oil Cleaner System) are considered to be "gimmicks" by many professional and expert automotive people.I also understand that there ARE a lot of "gimmicks" out there. My experience of literally multiple hundreds of thousands of miles of driving on multiple vehicles (I also had a 1959 Studebaker Hawk that had a FOCS and a 1967 Fiat Abarth OT1000 Bertone Spyder that had a FOCS) is that it really DOES work. It keeps the Oil clean and free of moisture. The anecdotes, such as paper fiber in the oil and etc., has not been experienced by any of my vehicles on which the FOCS has been installed. And all the warnings about not changing the Oil will result in very short Engine life has not proven to be the case. BTW, let me mention another strange and maybe weird thing that my father did with Ms. American. He drilled 1/16" holes in the lowest points of the Exhaust Pipes, he said to let the moisture out of the pipes. Does THAT work? I don't know, but Ms. American still has her ORIGINAL Exhaust System after fifty years and almost 300,000 miles of driving. Ms. American was built on March 19, 1964. She will turn 50 years old on March 19, 2014. Anyway, regardless of conclusions, this has been a lively and interesting discussion. Am eagerly awaiting the unfortunate (but well deserved) demise of these FOCS equipped Engines. Will let you all know when and how it happens. OK? But I'm not going to try to hold my breath till it does. Take care. JC |
| Author: | wjajr [ Sun Feb 23, 2014 10:55 pm ] |
I wouldn't expect anything less from hot running flat head, breather tube hanging off the oil pan, non PCV equipped running non detergent single weight oil. Any of those poorly vented engines I have had a chance to have seen apart were always caked up messes.
| Page 1 of 2 | All times are UTC-08:00 |
