fuel line loose, okay or not?
https://mail.slantsix.org/forum/viewtopic.php?t=5556
Author:  Andy's GT [ Wed Apr 23, 2003 11:42 am ]
Post subject:  fuel line loose, okay or not?
we pulled the gas tank on our 67 dart gt, the metal fuel line going into it is loose, its not supposed to do that, is it?:?
thanks!
Author:  DD on the Road [ Thu Apr 24, 2003 1:06 pm ]
Post subject:  Fuel line and sending unit..
Sounds like the solder joint is broken were it goes into the plate, resolder it or you will have a leak.
Aloha,
Author:  Dart270 [ Thu Apr 24, 2003 1:57 pm ]
Looks like Doug IS an e-addict. Checkin' the site from Hawaii. :shock: :wink:
Author:  Andy's GT [ Fri Apr 25, 2003 1:23 am ]
Post subject:  Leak
Thanks...we filled the tank yesterday prior to seeing your reply...and yes, it leaks! :cry:
What do you think about using JB Weld or a similar product?
Thanks
Author:  Michael_Cuda [ Fri Apr 25, 2003 1:37 am ]
Post subject:  Yep
I had this problem in my 67 Barracuda.... it was loose there.. except I didnt figure it out... I thought it was leaking as the seal..... if you any good at sodering... Fix it yourself... all you need to do is cook out the old soder... and redo it up again... make sure to align it right thou... otherwise you can take it to a raditor shop.....
Author:  Pierre [ Fri Apr 25, 2003 1:45 am ]
And make sure its no where near gas when your soldering... solder metal, metal get hot, gas get hot.... you'll have a bigger problem then a fuel leak ;)
Author:  Dart270 [ Fri Apr 25, 2003 6:15 am ]
If you don't want to solder it yourself, I like the radiator shop idea. You can also buy a whole new sending/pickup unit from Year One or Laysons or Paddock for around $70.
