It is currently Wed Nov 19, 2025 2:25 am
 Post subject: Hyperpak Carb Spacer
PostPosted: Sun Feb 22, 2015 10:02 am
Anyone using a carburetor spacer with a Hyperpak intake? Any benefits or negatives? I ran a 2" 4-hole spacer with the Clifford intake i had. Car is used strictly on the track.
1972 Dodge Dart
Best ET & MPH 14.26 @ 92
 Post subject: Nope.
PostPosted: Sun Feb 22, 2015 12:48 pm
I don't since the runners and plenum are longer and larger than the regular intake, you won't get any more low-mid range torque out of the hyperpak... big negative...your hood gets to suffer...with the clifford adaptor plate on it, you can't get an air cleaner on it and you have to cut a main web on your hood to get it to fit...use a standard thickness air filter and a hole needs to be installed in the hood....
