It is currently Wed Nov 19, 2025 5:49 pm
 Post subject: Nitrous tank safety
PostPosted: Mon Dec 29, 2014 8:34 pm
Can I leave a nos tank in the back of my station wagon in the summer sun ??
Tank would have a tank blanket on it not in direct sun and windows will have light or medium tint ...
I would have a blow down tube on it ....
Thanks
1963 Plymouth Valiant Wagon
PostPosted: Mon Dec 29, 2014 11:14 pm
Not really a good idea. If the burst disc fails to rupture you could have a bad day. When I was spraying my Valiant I really had to be careful because the tank would build pressure pretty quickly in a closed trunk.
PostPosted: Tue Dec 30, 2014 6:37 am
I'm with Slantzilla, on this. During the summer, I keep a wet towel in the car, and put it over the tank, if the pressure gets over about 1050 lbs. I had a safety disk rupture on a tank, in the back of my pickup, on the way to a race.
PostPosted: Tue Dec 30, 2014 7:30 am
Thanks makes for s easy choice ...
If I had 1/2 bottle would that help ? Or not enough .....
PostPosted: Tue Dec 30, 2014 9:10 am
On a ten lb bottle, it doesn't make any difference if there are 10 lbs in the bottle or 1 lb in the bottle, the pressure will be the same at the same temp.
The only thing that will make a difference is, if the bottle is over full, it will burst easier, as there will be no "head" space, and will hydrolic.
