| 67 Dart Fuel tank- I need to change one. https://mail.slantsix.org/forum/viewtopic.php?t=5792 |
| Author: | Mguesto [ Mon May 19, 2003 12:40 pm ] |
| Post subject: | 67 Dart Fuel tank- I need to change one. |
Long winded story with questions.. I found that the 67 Dart that I just bought had a patch on the fuel tank. After filling up the tank. I had some spots on my garage floor. When I took a closer look I found that the tank is now leaking in another area. It is in a location that I can see it is on top of the tank, but can't tell from where. If I have it just over 3/4 it is o.k. So now I have some time to look around for a replacement tank. Has anyone had experience doing this? Is this something that anyone can do or should it be brought to a garage to have done. ( I do not have a lift) What else should I expect to do to it while changing the tank? I saw on a web site that there is some sort of insulation (?) to help against rattles, etc. Something like tar paper.. Is there more than one tank for a convertible? Should I change the strap(s) as a normal thing to do? And last but not least, Where is a place that sells them? I have read some vendors are not very good to buy from. So I will ask for suggestions here. Car shows at Carlisle (Pa) are coming up often enough to get one there from a vendor. Again, thanks for your time helping me. Matt |
| Author: | Middy [ Wed May 21, 2003 7:28 am ] |
A new repro tank should be fairly easy to find they make them just up the road from me about an hour. I had a hernia at the time I purchased mine for the Dart so I had the local rad shop here do it for me. If I had been of able body I would have tried to do it myself. FSM is very handy if you can find one. Good Luck. |
| Author: | Guest [ Sat May 31, 2003 10:27 pm ] |
I replaced the tank in my son's 63 dart - got one through Quanta (gastanks.com) It was an American Designers replica - JC Whitney sells these also - It went in with no modification and after 2 years we have no problems. The hardest part for us is getting the gas out of the tank - you need an awful lot of gas gans to hold the fuel even when the guage reads 1/4. Also remember any sparks will ignite the fumes - NO DROP LIGHTS they explode with a drop of fuel ! |
| Author: | relic-lover [ Fri Jun 27, 2003 9:13 pm ] |
| Post subject: | Repro gas tank on ebay - 2 days to go |
There is a American Designers CR11 gas tank for Mopar on Eb ay http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2420733619 |
| Author: | DusterIdiot [ Fri Jun 27, 2003 11:05 pm ] |
| Post subject: | Too bad you're not local... |
I know a junkyard locally that has a 67 Dart GT in it, still has it's gas tank. If you were local it'd make a cheap/quick fix, buying new would be a better shot, unless your pocket book dictates otherwise.... -D.Idiot |
