It is currently Mon Nov 17, 2025 2:51 pm
 Post subject: 241 Poly V8 Running
PostPosted: Sun May 22, 2016 3:56 pm
I got my '54 Dodge pickup to run. Driving will take a lot more work. 1954 Dodge C1-B8 241 poly engine idle: https://youtu.be/-e_dNjwumQg
Here's what I'm working on. https://drive.google.com/file/d/0B8Nx2X ... cslist_api
PostPosted: Sun May 22, 2016 5:08 pm
Sweet!
PostPosted: Sun May 22, 2016 6:47 pm
Nice!
PostPosted: Sun May 22, 2016 7:04 pm
I ran it long enough to get hot and discovered that there is water in the cooling system which means it holds water! I was half expecting rotted core plugs. I don't know if you can tell in the video, but it spits back through the carburetor a bit so I'm sure there is at least one leaky intake valve. I drained the oil and didn't find anything alarming so I'll concentrate on brakes and wiring for now.
PostPosted: Sun May 22, 2016 7:55 pm
congrats!
