| My 1983 B150 Van https://mail.slantsix.org/forum/viewtopic.php?t=60287 |
| Author: | Reed [ Sun Oct 09, 2016 10:50 pm ] |
Nice score! I love slant six vans. I think you got good deal that just needs a little work to be a good daily driver. Don't stress the headliner, it is easy to make one out of whatever material you want. With some basic hand tools and creativity you can do whatever you want to the interior of your van. Get that solenoid installed propelry and see if your engine problems don't improve. |
| Author: | mwbean [ Mon Oct 10, 2016 2:31 am ] |
Reed, Thanks yea i only paid $2000 for it btw i just took the selonoid loose to see of i could clean up the numbers on the carb to see what model It is, i think a 1945? What do you think? The problem is it won't stay running after A few minutes of warm up time. |
| Author: | Reed [ Mon Oct 10, 2016 7:45 am ] |
That carb is either a Holley 1945 or a Holley 6145. I would need to see a picture of each side of the carb to tell you which. |
| Author: | Reed [ Fri Oct 14, 2016 10:39 pm ] |
I'm going to say it is a 1945 but it has an old "remanufactured" sticker on it. Dying after running for a few minutes sounds like either or both a vacuum leak and/or a problem with the curb idle circuit. It sounds like the choke keeps the engine running while it is onand the engine either leans out when the choke comes off or the curb idle speed screw is not set up properly. The first thing I would do is get that idle stop solenoid screwed back in position and set the curb idle speed properly (if possible). If that doesn't work, I say it is stime to rebuild that carb. Disassemble it, clean it, new gaskets, and adjust it. The see if it won't idle. |
