It is currently Mon Nov 17, 2025 11:28 pm
 Post subject: Kickdown ???
PostPosted: Sat May 27, 2017 4:17 am
For my race car. Is there any reason not to just do away with the kick down cable all together and just fasten the kick down lever fully rearward? I shift manually all the time anyway. Just figure I am installing another throttle cable and why not just eliminate this if it causes no problems. The car has a standard valve body it.
Rick
PostPosted: Sat May 27, 2017 6:05 am
Yes, you can do that. It will shift really high and hard if it is in drive. I have wired mine almost all the way back so it is not so high RPM and violent when driving around normally. Why not keep the kickdown cable you have already?
PostPosted: Sat May 27, 2017 2:59 pm
I can, and I may. :lol:
Thanks
PostPosted: Sat May 27, 2017 5:59 pm
Car Model: '23 T-bucket
Rick; Might I suggest you rig up a way to add a turnbuckle in place of the linkage. You could then adjust the turnbuckle to get shift points at a given RPM, being as it's a dedicated drag car, and doesn't see street duty.
If you're using a 904, then there's a round ear/hole forward of the kickdown shaft, right in the transition from bell housing to trans case, on the driver's side, that you should be able to utilize as an anchor point for the turnbuckle.
Roger
PostPosted: Tue May 30, 2017 11:49 am
I think Greg made a somewhat adjustable bracket on the Ruster at one time.
PostPosted: Tue May 30, 2017 12:02 pm
Yes i did.. then when i went to an a and a full manual forward pattern vb then i did not need it anymore as that vb has no kivkdown at all.
