Gas tank for my 62 Lancer
https://mail.slantsix.org/forum/viewtopic.php?t=60865
Page 1 of 2
Author:  JohnnyDees [ Sat Mar 04, 2017 3:50 pm ]
Post subject:  Gas tank for my 62 Lancer
I think Im going to try the 63 Dart tank in my 62 Lancer. I found these on ebay and was wondering if anyone knew these companies.
http://www.ebay.com/itm/131469060394?_t ... EBIDX%3AIT
http://www.ebay.com/itm/Fuel-Gas-Tank-1 ... 1469060394
Thanks for any help
Author:  hyper_pak [ Sat Mar 04, 2017 6:02 pm ]
Post subject:  Same Questions
This is good timing for me. I have a 62 tank that I am looking at getting cleaned and then powdercoated. All that will be much more than what these company's are asking for.
What worries me are these look like the same tanks from the pictures.
18 gallon sounds like a lot larger than the 13 that I think the 62 tank is.
I can't tell from the pictures what the fuel inlet looks like.
The 62 has just a little grommet that seals the filler tube to the tank.
One good thing, it looks like the mount strap runs right to left!
Any one else have any thoughts??
Author:  JohnnyDees [ Sun Mar 05, 2017 6:35 pm ]
I had some of the same question s , it was just such a good price , hard to tell the quality though, spectra tanks seem good but go for $170
Author:  nuttyprof [ Mon Mar 06, 2017 4:59 pm ]
The 63 tank fits in a 62, that is what I have right now. The issue you will need to deal with is the sending unit needs to match the tank ( the 62 is on the right side of the tank front and the 63 is centered on the front and uses a different sender, wires and fuel line need relocated ) The fill tube works like the original. The tank has more capacity because it extends farther back around the spare tire well.
Author:  hyper_pak [ Mon Mar 06, 2017 6:02 pm ]
Post subject:  63 Tank
Good info! Did you locate a 63 sending unit for your tank, remember the supplier for the sending unit? Grommet worked well on the stock filler tube?
Author:  JohnnyDees [ Mon Mar 06, 2017 7:13 pm ]
I just bought a spectra tank for $120 with free shipping on Ebay. Now I need the sending unit. Is it worth getting the 3/8 unit, I will hope fully be upgrading to turbo in the future.
Thanks,
Author:  nuttyprof [ Mon Mar 06, 2017 7:56 pm ]
Do not remember the supplier, but the sender came from the same place as the tank. I got a new grommet as well, it was the same as the 62 part.
Author:  JohnnyDees [ Thu Mar 23, 2017 5:45 pm ]
well I went with all spectra products. Got good deals on tank and sending unit. What has anyone used for the material that sits on top of the tank?
Thanks
Author:  SlantSixDan [ Thu Mar 23, 2017 6:12 pm ]
I'm sure not fixin' to put in a tank pad made of any kind of porous material (gets wet...stays wet...rusts whatever metal is next to it). I rather use a thickness or two of this cheap and easily locally available stuff.
Author:  hyper_pak [ Thu Mar 23, 2017 7:03 pm ]
Post subject:  Gas tank pad
I got one from REM for a mid 60's A body. Just for information.
Author:  Greg Ondayko [ Fri Mar 24, 2017 8:59 am ]
Rem for Originality.
Cut up rubber roofing or old interubes for cheap and easy functionality.
Author:  JohnnyDees [ Fri Mar 24, 2017 6:10 pm ]
Thanks for the suggestions.
Author:  JohnnyDees [ Wed Apr 12, 2017 6:16 pm ]
Does anyone know a source for a 62 Lancer gas tank strap?
Thanks
Author:  Rob Simmons [ Thu Dec 27, 2018 2:35 pm ]
Post subject:  Re: Gas tank for my 62 Lancer
Do you still need the strap? It's been over a year, so probably not...
Author:  JohnnyDees [ Sun Jan 13, 2019 5:13 pm ]
Thanks, I found a strap now just have to figure out how to use it to mount a 63 tank in my 62 Lancer.
Page 1 of 2 All times are UTC-08:00
