| Holset wastegate conversion https://mail.slantsix.org/forum/viewtopic.php?t=60938 |
| Author: | Ccrussell [ Tue Mar 28, 2017 8:29 am ] |
| Post subject: | Holset wastegate conversion |
Hello, I purchased a used Holset hx35. Is currently internally wastegated, and i would like to convert it to external wastegate for better control. One of two ways to achieve this; i can change the exhaust housing to eliminate the internal, or purchase a block off plate to accomplish the same thing. I am not sure exactly how the other components will attach (wastegate and exhaust pipe). $135 for the housing, or $35 for the block off plate. Any thoughts? |
| Author: | Joshie225 [ Tue Mar 28, 2017 9:12 am ] |
Unless this is a competitive race application (and I can tell it's not because you're not using a $2500 ball bearing turbo) I would save the money and use the internal wastegate with a lower pressure actuator. |
| Author: | Ccrussell [ Tue Mar 28, 2017 10:58 am ] |
Thanks, Appreciate to speedy reply. Will search for what you suggest. Hoping to find something starting with 5 psi, that i might creep up to 10 plus psi. Russ |
| Author: | ProCycle [ Tue Mar 28, 2017 12:26 pm ] |
I got a nice adjustable waste gate actuator from Kinugawa It fits nice on the Holset - half way down this page: http://www.slantsix.org/forum/viewtopic ... c&start=75
| Author: | Junior [ Tue Apr 04, 2017 6:00 pm ] |
hx35 is a lot of turbo for that little bit of boost. you could go much smaller and make i more responsive and still push what you are looking for. i doubt the hx is in its efficiency range at that low flow. |
