LBP and SBP
https://mail.slantsix.org/forum/viewtopic.php?t=60955
Author:  JohnnyDees [ Sat Apr 01, 2017 1:45 pm ]
Post subject:  LBP and SBP
Can I run big pattern on rear and have small bolt pattern on front?
Author:  Reed [ Sat Apr 01, 2017 1:57 pm ]
Sure. You will just have to carry two spares -- one for each bolt pattern. You might also look into wheel bolt pattern adapters for the front and run LBP front and back.
Author:  sandy in BC [ Sat Apr 01, 2017 4:11 pm ]
Its pretty easy to change the front.
The larger pattern give many more options.
Author:  JohnnyDees [ Sat Apr 01, 2017 6:14 pm ]
I will do the front at some point, I found a 7 1/4 with posi that Im thinking of buying and it has BBP.
Author:  SpaceFrank [ Fri Apr 28, 2017 1:36 pm ]
That gives you a good excuse to do a front disc brake upgrade in the future. Most people looking at that swap have to consider the opposite problem (LBP in front, SBP in back).
