It is currently Wed Nov 19, 2025 8:41 pm
PostPosted: Wed Jun 06, 2018 7:24 pm
What intakes, besides Clifford, if any, have the cast in bosses for injector bungs?
PostPosted: Thu Jun 07, 2018 1:57 am
Aussiespeed intakes do as well, at least all of them I have seen. The runner areas are not as large as Clifford, so not as good for high HP, high RPM usage.
PostPosted: Thu Jun 07, 2018 6:07 am
My Clifford H-Pak has bosses but they are perpendicular to the ports, not angled like on the Ram Flo.
PostPosted: Thu Jun 07, 2018 6:12 am
They are smaller than a standard bung for for EFI, they were cast for nitrous only.
When you machine this manifold for EFI you will completely wipe out those bosses,
especially if you want the injector at an angle, FYI.
PostPosted: Thu Jun 07, 2018 6:41 am
Interesting, thanks. I have been thinking about the h-pak due to the long runners. It sounds like using the h-pak would require welding in new bungs, though. I need to research how well the aussiespeed intakes clear factory accessoris like AC.
PostPosted: Thu Jun 07, 2018 5:13 pm
Neither long ram will be conducive to having something in the area that the AIR or AC compressor would be located... they work fine with
PS or the alternator relocate... but at least in the HPak's case, you also need to install a kickstand, or a good pothole will break a couple of
studs and you will be paying $$$ to reinstall the whole manifold stack again to reach them....
PostPosted: Thu Jun 07, 2018 8:27 pm
Well, poo. I guess I will just stick with the Offy I got from Wesola and drill weld in some bungs.
