It is currently Thu Nov 20, 2025 2:27 am
PostPosted: Mon Jul 14, 2003 9:41 pm
in my 74 swinger, i have what feels like its got a bit of oversteer going on. when i get hauling A around a good corner, it almost feels like the back is going to come around any moment. it has addco bars front and rear with i bielive .890 bars if i remember. all that was in it when i bought the car. i also have 15x7 cop rims and 225/50r15 dunlop tires on all four corners. how can i plant the rear more? doin 70+ around a sweeet on ramp is a blast but the last thing i want to do is spin out. it feels like it will any moment. i have .920 bars i will be installing also so i know this will also change things. help please
--chad
PostPosted: Mon Jul 14, 2003 9:42 pm
sorry---forgot to sign in when i wrote that.
--chad
74 swinger slant 6, the slowest, most fun car i have ever owned.
PostPosted: Mon Jul 14, 2003 10:18 pm
I'm not an expert, but I would try a larger sway bar on the front.
PostPosted: Tue Jul 15, 2003 1:25 am
If you stiffen-up the front with bigger T. bars and anti-sway bar, that will help. The front wheels will want to "push" (understeer) as things stiffen-up.
How are all the leaf spring bushings in back, worn leaf spring bushings makes the rear feel like it's going to break loose.
PostPosted: Tue Jul 15, 2003 8:17 am
Ditto what Doc said about leaf bushings. I found the poly rear leaf bushings helped out. Stiffening the front end would be good, but you could also remove the rear sway bar, or remove a leaf from each leaf pack to soften the rear. Either will reduce oversteer. Most A-body handling guys I know of, including me, do not run a rear sway bar.
Have fun,
PostPosted: Tue Jul 15, 2003 8:41 pm
well, i know i need to redo the rear suspension. it needs new leafs and a good set of shocks all around. im very happy with how the car handles......i just want more. i will get these .920 bars installed soon i hope and report back. thanks for your help--i prob would have tried to stiffen the rear not knowing any better.
--chad
