| 10 inch brake question https://mail.slantsix.org/forum/viewtopic.php?t=62121 |
| Author: | Charrlie_S [ Thu Mar 22, 2018 5:46 pm ] |
| Post subject: | 10 inch brake question |
72 duster 10 inch front brakes, small bolt pattern. Does any one know if 10 inch "B" body hub and drum could be put on the "A" body spindle to get big bolt pattern. I'm thinking, not. |
| Author: | sandy in BC [ Thu Mar 22, 2018 6:22 pm ] |
| Post subject: | Re: 10 inch brake question |
I think the outer bearings are the same... |
| Author: | kesteb [ Thu Mar 22, 2018 8:49 pm ] |
With the '73 and later big ball joint upper control arm, you can use the whole B body spindle and drum brake setup. |
| Author: | Joshie225 [ Fri Mar 23, 2018 7:42 am ] |
No, the bearings (at least one) are different. I went through this with my '66 Barracuda. There is an AMC hub which uses the same bearings, but I wasn't able to find a seal. I ended up not using any of the original front brakes. I torched out the small upper ball joint and welded in a sleeve to accept the big ball joint and used late A-body drum spindles which are essentially B-body spindles. |
| Author: | Charrlie_S [ Fri Mar 23, 2018 8:42 am ] |
Quote: used late A-body drum spindles which are essentially B-body spindles.
What do you consider "late" A body drum spindles? I thought the 72 "A" 10 spindles were the same up to when disc was standard.
| Author: | Slant Cecil [ Fri Mar 23, 2018 11:45 am ] |
Quote: With the '73 and later big ball joint upper control arm, you can use the whole B body spindle and drum brake setup.
I'm 99.9% sure this will work. '68-'70 B body spindle/brake assembly with a '73-'76 A body upper a-arm. |
| Author: | Joshie225 [ Fri Mar 23, 2018 2:48 pm ] |
Quote: Quote: used late A-body drum spindles which are essentially B-body spindles.
What do you consider "late" A body drum spindles? I thought the 72 "A" 10 spindles were the same up to when disc was standard. |
| Author: | Charrlie_S [ Fri Mar 23, 2018 5:06 pm ] |
So, from what I am reading, it is not going to work, just putting "B" body 10 drums and hubs, on a 72 "A" body spindle |
| Author: | Joshie225 [ Sat Mar 24, 2018 11:04 am ] |
Quote: So, from what I am reading, it is not going to work, just putting "B" body 10 drums and hubs, on a 72 "A" body spindle
Correct. Go look at the bearings used (rockauto.com) and you'll see why.
| Author: | Charrlie_S [ Sat Mar 24, 2018 1:47 pm ] |
Thanks, that's what I thought, but I was asked by someone, and I didn't have the answer. |
| Author: | WillyPete67 [ Mon May 14, 2018 8:28 am ] |
Quote: 72 duster 10 inch front brakes, small bolt pattern. Does any one know if 10 inch "B" body hub and drum could be put on the "A" body spindle to get big bolt pattern. I'm thinking, not. First off, why stay with drum when you can get disc? Just bolt on a set of 73-76 spindles from a duster. they should bolt on directly.
| Author: | Charrlie_S [ Mon May 14, 2018 2:22 pm ] |
Quote: Quote: 72 duster 10 inch front brakes, small bolt pattern. Does any one know if 10 inch "B" body hub and drum could be put on the "A" body spindle to get big bolt pattern. I'm thinking, not. First off, why stay with drum when you can get disc? Just bolt on a set of 73-76 spindles from a duster. they should bolt on directly. |
