It is currently Wed Nov 19, 2025 8:44 pm
 Post subject: Wheel vintiques
PostPosted: Mon Apr 16, 2018 5:26 pm
Car Model: 62 Lancer GT
I am thinking of buying some 14 x 7 steelies from wheel vintiques with extra backspace for my b body rear end. They told me that they don't make wheels specifically for mopa r and the hub is 3.25 inches to accommodate more brands. They said they're wheels are not concentric so it doesn't matter. Has anyone used wheel vintiques before and will this work?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
 Post subject: Re: Wheel vintiques
PostPosted: Tue Apr 17, 2018 1:34 am
Wheel vintiques Mopar steel wheels have correct center bore, but those are available only 15" diameter. Many aftermarket wheels have larger center bore, you need to use centering rings with them. Or not, carefully tighten nuts and you'll (probably) be fine. But it is better with centering rings.
https://www.summitracing.com/int/parts/ ... /overview/
http://us.hubcentric-rings.com/
PostPosted: Thu Apr 19, 2018 6:12 pm
Thanks. I might go with 15s but it's good to know
1966 Dart GT
62 Lancer GT
B Body 8 3/4
