Cam Driven Pump
https://mail.slantsix.org/forum/viewtopic.php?t=62200
Page 1 of 2
Author:  ceej [ Fri Apr 13, 2018 4:40 pm ]
Post subject:  Cam Driven Pump
Has anyone any detail on setting up a pump drive on the slant six cam? We have a single Bolt cam gear. Is there a gear or drive system that anyone has used on the slant six?
We have some ideas, but I'd like to see and hear about what others have done.
CJ
Author:  Charrlie_S [ Sat Apr 14, 2018 3:52 am ]
Post subject:  Re: Cam Driven Pump
Are you talking about a fuel pump drive, or oil pump? Most people using a external drive, for either or both use a crank drive system. I've never used one myself, so can't advise. I know Ron Hamby uses a crank drive system, as do several others.
Author:  ceej [ Sat Apr 14, 2018 8:41 pm ]
Post subject:  Re: Cam Driven Pump Need a Cam Spud.
Both fuel pump and oil pump will run off the cam. A cam spud.
I'd like to see a pic of one of their crank mounted setups.
CJ
Author:  Charrlie_S [ Sun Apr 15, 2018 4:04 am ]
Send a PM to Ron. I would also send a PM to Rick and/or Ryan Covalt. They have tons of pictures of slant six cars, and probably have some of a pump drive.
Author:  Exner Geek [ Sun Apr 15, 2018 6:04 am ]
I think that the fuel pump on Mark Goodman's dragster is driven off the cam. Maybe he can help.
Author:  slantzilla [ Sun Apr 15, 2018 9:05 am ]
CJ
Wasn't it Hilborn that had the cam drive injection pump? I know why you're want to cam drive everything Ceej, but I'd think the oil pump would put quite a load on the cam gear. :?
Author:  Team Green [ Sun Apr 15, 2018 1:08 pm ]
ImagePICT0090 by A G, on Flickr
ImagePICT0082 by A G, on Flickr
ImagePICT0079 by A G, on Flickr
Author:  Dart270 [ Sun Apr 15, 2018 1:10 pm ]
Mysteries of the universe, revealed...
Author:  Rick Covalt [ Sun Apr 15, 2018 1:19 pm ]
WOW!!! Quite beautiful work Mark! Thanks for sharing.
Author:  ceej [ Sun Apr 15, 2018 1:39 pm ]
Very nice! Unfortunately this solution exceeds the limitations of my machine tools and skill level with them.
Last time I checked, slant gear drives were no longer available. Is there a source for them still?
CJ
Author:  Team Green [ Sun Apr 15, 2018 3:45 pm ]
Thanks for compliments. I bet Ceej can build it. I had machine shop in high school 40+ years ago and my Bridgeport mill,South Bend lathe both did duty during the Korean War.
The gear drive is a Pete Jackson for a BBM. To adapt to a slant is to make a spacer of .400 to move the cam gear forward or cut the crankshaft.
Seymour is right, we started with the tractor engine and the pump was ran off the front of the cam. The pump was too high for the fuel level of the tank. We had to prime the thing every time we started it. Not fun.
Mark
Author:  Badvert65 [ Sun Apr 15, 2018 3:49 pm ]
Wow x2!!
That is art work.
How about some pics of the rest of the car (in another post-bad enough I hijacked this one).
Author:  Team Green [ Tue Apr 17, 2018 5:09 pm ]
Imagegernade by A G, on Flickr
Imagegernade2 by A G, on Flickr
Ceej are you going to run a fabricated fuel tank between the frame rails or a tank above the rails? The Grenade just didn't work the best with the setup in the photo.
Author:  slantzilla [ Tue Apr 17, 2018 7:09 pm ]
You build absolutely beautiful stuff Mark! :D
Author:  Greg Ondayko [ Wed Apr 18, 2018 8:49 am ]
Lookin good team green!
Yer team needs a green weenie car now to round out the fleet.
Green 74 colt.
Cheers,
Page 1 of 2 All times are UTC-08:00
