It is currently Tue Nov 18, 2025 10:37 pm
PostPosted: Sat Apr 28, 2018 2:22 pm
So, I'm working on a 71 Dart, but can't get fuel to the carb.
I replaced the fuel pump and attempted to draw fuel from a portable can. I've also disconnected the line to the carb, but don't see any fuel making it there. The line is clear of clogs.
No fuel when cranking engine.
So, I removed and reinstalled the new fuel pump to verify arm is making contact with Cam and... Still no fuel.
What am I missing? It is a brand new fuel pump from NAPA.
Thanks in advance for your suggestions!
burg
PostPosted: Sat Apr 28, 2018 3:07 pm
Car Model: '23 T-bucket
Have you confirmed that you have a clear line form the tank to the pump?
Paper fuel filters are known to get blocked by water in the filter. I've seen more than once, water in a paper filter, and it wouldn't flow gas.
I have known of old rubber fuel hose to get blocked by the inner wall peeling loose and stopping fuel flow.
Is your needle/seat stuck in the closed position?
Roger
PostPosted: Sat Apr 28, 2018 3:22 pm
Is the pump lobe worn flat on the cam?
PostPosted: Sat Apr 28, 2018 3:36 pm
Well, I may have cried wolf too soon...
It looks like I didn't have enough fuel in the temporary can to develop any head pressure.
With a full can it immediately filled the filter with fuel and started up when connected to carb.
I'm still planning to replace the tank and sending unit, but first I will need to diagnose the blue cloud!
Thanks for the suggestions!
burg
PostPosted: Sat Apr 28, 2018 5:12 pm
You're welcome. "Blue cloud" at startup, then it clears, or is it constant?
Roger
PostPosted: Sat Apr 28, 2018 6:45 pm
Blue cloud when rpms higher than idle.
I'm hoping it's just valve seats leaking, or it could be sticking rings.
I started with the fuel pump and fresh oil and filter to confirm it would run, but it needs several more tune up items before I test drive it.
burg
PostPosted: Sun Apr 29, 2018 3:42 am
You could be correct. If this car sat for a long time, the problems may just go away with a tuneup and a little running time.
You might want to pull the plugs for a look-see. That could give you more information for a diagnosis.
Roger
PostPosted: Sun Apr 29, 2018 8:11 am
https://www.youtube.com/watch?v=AynXoLjYrKc
:D :D :D :D :D
Users browsing this forum: No registered users and 34 guests
