exhaust around oil pan
https://mail.slantsix.org/forum/viewtopic.php?t=62287
Author:  Mongrel147 [ Wed May 02, 2018 9:24 am ]
Post subject:  exhaust around oil pan
My 1938 Plymouth has a 74 Duster 225/6-904 being installed in the chassis. Dues to chassis x member clearance issues, there is no room for the exhaust to go down the drivers side of the engine/transmission. I was considering running the exhaust under the oil pan with a way to "split" (take apart) it if there was a need to remove the pan. Any ideas for heat wrap, heat shields, connections, and clearance distance needed. Any other suggestions would be appreciated.
Author:  Dart270 [ Wed May 02, 2018 9:42 am ]
Post subject:  Re: exhaust around oil pan
Welcome to the site. Sounds like a super cool project. I believe Aspens/Volares had this format on Slants, under the back of the sump and to the pass side.
I would keep it 0.5" away from the oil pan and use thermotec heat wrap tape (attached w/hose clamps or stainless zip ties/clamps) in the area of the oilpan. I have had one tube of a header bump/rest against the driver side of the oilpan at one point and had no ill effects.
Happy building,
Author:  Greg Ondayko [ Wed May 02, 2018 11:11 am ]
On the F bodies the exhaaust crosses under the trans for slant 6 models - after the bellhousing but before the auto trans Pan - I have no Stock slant 6 F bodies anymore, but I think that is where it crossed over.
Author:  sandy in BC [ Wed May 02, 2018 11:47 am ]
I would definitely look at the F body crossover pipe.
You might find a stock pipe that fits. That's good as they are larger than earlier setups.
Author:  Badvert65 [ Wed May 02, 2018 12:15 pm ]
You can't tell by the diagram, but the F body slant exhaust does cross over to the passenger side. Basically goes under the oil pan in front of the trans. That is how my Volare wagon was.
Author:  DusterIdiot [ Wed May 02, 2018 4:29 pm ]
That routing is correct. I still have the stock super six "header" from the 78 Aspen and it's 2 1/4" for that pipe...
I use this same header configuration as the rear on my dutra duals if doing true dual pipes.
