It is currently Tue Nov 18, 2025 5:10 am
PostPosted: Mon May 14, 2018 9:45 am
Car Model: 1966 Clark Cortez
Off topic I know but thought this group would have some good insights. My old Cortez Motorhome (yes it runs on a '66 industrial slant 6!) is in need of some new windshields. The problem is the OEM 2 part gasket no longer exists, compounded by the fact that the glass has square corners. I've decided against trying to miter the gasket as I'm sure over time it will be problematic. My choices now are 1) Weld on a larger window frame in order to glue in a window (there isn't enough material to glue to at the moment), or 2) Weld in some radius corners in order to remove the need for miters, and use the 2 piece rubber.
I'd be interested in this group's thoughts/experience.
Thank you
1966 Clark Cortez Motorhome w/
Industrial Slant 6 looking for adventure!
Users browsing this forum: Bing [Bot] and 17 guests
