It is currently Mon Nov 17, 2025 5:57 pm
PostPosted: Sat Aug 18, 2018 7:44 am
Anyone in here ever done this? I picked up a spring that is missing on my driver door hinge. Anyone able to tell me the steps on removing the door and putting the new spring in? Thanks
PostPosted: Tue Aug 21, 2018 6:16 pm
Should not have to remove the entire door, loosen both, block door with a floor jack and take out the one you need to work on, with them both loose you should be able to fish it out.
