| Guidos turbo ve valiant https://mail.slantsix.org/forum/viewtopic.php?t=62679 |
| Author: | Vgute [ Sun Aug 05, 2018 5:47 pm ] |
| Post subject: | Guidos turbo ve valiant |
Hello everybody, well am going to turbo my 1968 ve valiant sedan. Nothing new of course. Have a read through the builds on here but still have a few questions. Car is running a 904, and 2.92 rear gearing at present, i do have a 3.89 that plan to fit to another diff for some drags. So engine is stock standard, from what i have read 10psi is fine, if timing is well sorted. Plan to pull the engine out to do a few mods. 225 stock engine- stock pistons, have read on here to gap rings to top- 0.024", and second to- 0.018"? - will stay with the standard camshaft( as from what i read is fine) - plan to upgrade valve springs to what ever you guys say - head, would pocket port if that was going to help - arp head and main studs - turbo, i have a cheap china knockoff of a to4e, exhaust is a/r 0.63 and compressor is a/r 0.50, am more than happy to replace this with a better? - wastegate, have a few here. But what ever you guys think - intake, aussiespeed hurricane - fuel, fitech 600pa with a extreme velocity hat, fitech 340lph intank pump - ignition, msd 6al2 6530, - intercooler, 600x200mm - exhaust manifold, i have a 6-1 s/s which is 1.5" so could make a custom set, very open to design, as would like to stepup later( engine wise) So i have all those parts, really keen to get on to this, |
| Author: | Vgute [ Mon Aug 06, 2018 5:06 pm ] |
| Post subject: | Re: Guidos turbo ve valiant |
So out of interest did a few calculations, here is what i got. 225cid CFM- 4500 rpm= 249 5000 rpm= 276 5500 rpm= 304 MASS FLOW RATE- 4500 rpm= 18.154 5000 rpm= 20.122 5500 rpm= 22.163 PRESSURE RATIO COMP- 7 psi= 1.34 10 psi= 1.54 15 psi= 1.98 HORSEPOWER 4500rpm 7psi= 243 10psi= 279 15psi= 360 5000rpm 7psi= 270 10psi= 310 15psi= 398 5500rpm 7psi= 297 10psi= 341 15psi= 439 TEMP OUT OF COMPRESSOR TEMP OUT OF INTERCOOLER 7psi= 103° 7psi= 14° 10psi= 180° 10psi= 71° 15psi= 240° 15psi= 116° |
