Jeep 6 Sniper?
https://mail.slantsix.org/forum/viewtopic.php?t=62728
Author:  Old6rodder [ Mon Aug 20, 2018 10:12 am ]
Post subject:  Jeep 6 Sniper?
I know diddly about EFI (and personally, care less :wink: ), but saw this over on Bangshift this morning, and thought of you EFI types here.
Author:  sandy in BC [ Mon Aug 20, 2018 12:38 pm ]
Post subject:  Re: Jeep 6 Sniper?
Take off a BBD and bolt on up to 350 hp.
A BBD flows 255cfm
Two 100lb injectors would drown a BBD compatible manifold at an idle.
Author:  Greg Ondayko [ Mon Aug 20, 2018 1:11 pm ]
You could set the pulse width at 0.00001 sec for idle quality... :D :D
Author:  GTS225 [ Mon Aug 20, 2018 4:02 pm ]
It says "supports up to 350 horse with 100 lb/hr injectors". That doesn't mean you have to get the big injectors, and I suspect Holley will want some intended use info before they send you the package.
Looks neat, but $1000 neat? I ain't so sure.
Wonder how it would work with a blow-through turbo or supercharger?
Roger
Author:  OGLeanDart270 [ Mon Aug 20, 2018 8:43 pm ]
I watched a vid and read some of the fine print. It states it is for normally aspirated engines only (although it does have a 2 bar map).
It is 100 bucks more than the 2300 version and the 2300 is nicer I think (universal air cleaner). They really did set this up as a jeep BBD replacement, not a generic BBD. If you look at the IAC motor on the throttle body it is just barely below where the air cleaner attatches, and sticks out quite a bit. The way jeep air cleaners bolt on it isn't in the way but I doubt a Super Six air cleaner would clear it. BBD carbs don't have anything in the way in that area.
Pretty sure the 100 lb injectors are fine, I think they alter fuel pressure or something to get them to idle on smaller motors. I have seen mild V6's with the 4 barrel that run and idle just fine and those are good to 650hp. There are even air cooled VW's running the four barrels. CFM would be a bit higher than a BBD as there is no venturi.
Brandon
Author:  coconuteater64 [ Tue Dec 11, 2018 5:52 am ]
For that money I'd just switch to propane for a simpler installation. Looks nice though.
