It is currently Mon Nov 17, 2025 11:11 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: Read This First!
PostPosted: Sat Jul 09, 2011 7:38 pm
Prior to entering any transaction, please note that the Moderators and Site Administrators do not sponsor listings or vouch that such listings are legitimate. If you have a poor purchasing experience, you will need to address the issue with the seller, your financial institution or the method used for payment. Moderators are volunteers from within the community, and are not equipped to pursue such matters for you.
Posts are automatically deleted after 60 days to reduce maintenance time.
NOTE: A "sticky" post can be set up by a moderator for items that are continuously available. You will need to contact a moderator to request this. A donation for this service is appreciated but not required, especially if you are a regular contributor to the board.
If you are selling something that isn't for a Slant Six, you are required to include that information in the body of the post, not just the header. Failure to do so may result in a suspension of your membership privileges if a problem arises from your post.
Please use common sense when purchasing from these listings. We can't do that for you.
Should you have a problem, let us know about it, and we will track the user's activity. Scammers will be removed from our membership.
Thank you for taking the time to read this.
