It is currently Wed Nov 19, 2025 5:33 pm
PostPosted: Thu May 23, 2019 11:35 am
In order to pass tech at most tracks do I need anything special to span from fuel cell to the stock hard line on the car? Can I use regular fuel line, fuel injection hose or do will I need to use braided steel line?
PostPosted: Thu May 23, 2019 12:26 pm
Looks like braided steel or approved push-lock hose and fittings. No hose clamps.
http://promod.nhra.com/userfiles/file/T ... ations.pdf
Lines: All non-OEM fuel lines (including gauge and/or data
recorder lines) must be metallic, steel braided, or NHRAaccepted “woven or woven-pushlock.” A maximum of 12 inches
total (front to rear) of non-metallic or non-steel braided hose
is permitted for connection purposes only; individual injector
nozzle and motorcycle fuel lines are excluded. Fuel lines (except
steel braided lines) in the flywheel/bellhousing area must be
enclosed in a 16-inch length of steel tubing, 1/8-inch-minimum
wall thickness, securely mounted as a protection against fuel-line
rupture. Fuel lines may not be routed in the driveshaft tunnel. It
is mandatory that fuel lines passing supercharger drive belts be
steel braided, NHRA-accepted woven or woven-pushlock, or
be enclosed in protective steel tubing. A current list of NHRAaccepted woven or woven-pushlock fuel lines is available on
NHRARacer.com. All NHRA-accepted fuel lines must use ends
that are specifically designed for the type of fuel line being used.
No hose clamps allowed on NHRA-accepted fuel lines.
PostPosted: Thu May 23, 2019 12:32 pm
Thanks Josh.
PostPosted: Thu May 23, 2019 12:55 pm
Those look like Promod rules, which are much more restrictive.
drgonzo, you are asking about your regular automotive car, aren't you?
Same maximum 12" of rubber hose line... Hose clamps should be okay.
PostPosted: Thu May 23, 2019 1:04 pm
Yes, my 63 dart, street-strip project. I don't mind using braided line or push lock or whatever I just have to figure out how to attach it to the stock 5/16 hard line that is on the car.
PostPosted: Fri May 24, 2019 7:22 am
your stock steel fuel line on the car is fine.
No more than 12" rubber fuel hose from the line to pump or pump to carb, or fule cell to line, etc.
Some tracks' tech scrutineers will dink you if the stock fuel line is run inside the frame rails by the bell housing... but on a stockish car that probably wont matter.
PostPosted: Fri May 24, 2019 7:30 am
Thanks Greg.
