| 63 Valiant shift cable o-ring https://mail.slantsix.org/forum/viewtopic.php?t=64029 |
| Author: | sixsignet [ Tue Sep 03, 2019 6:28 pm ] |
| Post subject: | 63 Valiant shift cable o-ring |
What size o-ring does the shift cable on a 1963 A904 use? |
| Author: | sixsignet [ Sat Sep 07, 2019 8:04 am ] |
| Post subject: | Re: 63 Valiant shift cable o-ring |
I cleaned the transmission fluid from the shift cable adjusting wheel area and the cable and tie-wrapped a paper towel around the cable. A week later, the paper towel is still dry and the adjusting wheel and surrounding area is wet. It is definitely the o-ring behind the adjusting wheel. Does anyone know the part number or size o-ring that is used? |
| Author: | SpaceFrank [ Tue Sep 17, 2019 2:59 pm ] |
I don't know the size. I just bought an assortment at the auto parts store and picked one that fit. |
| Author: | valiant_200 [ Sat Dec 07, 2019 11:10 am ] |
I've had to do this a couple of times now. There are a lot of O rings that look like they would fit, only to leak like a sieve when installed. What I ended up doing was buying a #91 O ring and wallowing out the inside just a bit with a fine sanding disk on a Dremel. Keep the Dremel moving and only take off enough rubber to make it barely small enough to slip it into the bore on the transmission case. I have done two transmissions this way and both of them are holding so far. |
| Author: | sixsignet [ Tue Jan 21, 2020 10:11 pm ] |
Quote: I've had to do this a couple of times now. There are a lot of O rings that look like they would fit, only to leak like a sieve when installed.
What I ended up doing was buying a #91 O ring and wallowing out the inside just a bit with a fine sanding disk on a Dremel. Keep the Dremel moving and only take off enough rubber to make it barely small enough to slip it into the bore on the transmission case. I have done two transmissions this way and both of them are holding so far. Do you mean a small sanding drum? |
| Author: | valiant_200 [ Wed Jan 22, 2020 1:37 pm ] |
I do mean a standing drum. Thanks for catching that error. |
| Author: | sixsignet [ Sat Jan 25, 2020 8:54 pm ] |
Thanks. I'm going to try that as soon as dry weather returns. |
