| A833 floor shifter https://mail.slantsix.org/forum/viewtopic.php?t=64181 |
| Author: | Pgbarrow [ Thu Oct 31, 2019 3:46 pm ] |
| Post subject: | A833 floor shifter |
Hi all, Can anyone give me some affordable recommendation for covering an A833 to floor shift? I had not thought about this until after I purchased the transmission. Gping into a rat rod. Thanks, Paul |
| Author: | Joshie225 [ Thu Oct 31, 2019 5:00 pm ] |
| Post subject: | Re: A833 floor shifter |
I'm slightly confused. All A833s are floor shift. |
| Author: | Pgbarrow [ Sun Nov 03, 2019 9:31 am ] |
I probably missed/don't understand something. I had thought there would be a stick pointing up out of the housing. Looking at the side panel, I thought there was some way you shifted from the column and that was transferred down into the transmission. |
| Author: | GTS225 [ Sun Nov 03, 2019 2:39 pm ] |
No, an A833 is a four forward gear, and one reverse gear trans. There's no way that it could be shifted from the column, as there's only four positions available in a column shifter. Can you post a pic of the side cover? Roger |
| Author: | Joshie225 [ Sun Nov 03, 2019 3:39 pm ] |
Many people seem to miss the articles section of the board. The 1st article is about 4-speeds. It's good reading. http://www.slantsix.org/articles/4-spee ... speed1.htm |
| Author: | Pgbarrow [ Mon Nov 04, 2019 9:58 am ] |
Thanks guys, I'll try and get a photo published soon. I had a very four year old's "stick comes out the top of the transmission" idea of what this was supposed to look like. Paul |
| Author: | slantzilla [ Mon Nov 04, 2019 10:04 am ] |
The 833 does not have a shift tower like late model transmissions. It requires a bolt-on shifter . |
| Author: | Pgbarrow [ Mon Nov 04, 2019 12:44 pm ] |
Got you, now I just need to find that. Hopefully for less than the ~$600 I have seen online. Paul |
