It is currently Mon Nov 17, 2025 8:48 am
 Post subject: Vapor lock
PostPosted: Wed Dec 30, 2020 8:21 pm
Car Model: 1974 Dodge D100
Hello all,
I have been getting this 74 Dodge D100 running and I am now struggling with vapor lock. I was told to put a fuel vapor separator in line between the fuel pump and carburetor but I am wondering if I can eliminate the charcoal canister and use the line that returns to the gas tank as a return line for the separator? The canister isn't being used anymore as the new carburetor doesn't have a vacuum nipple for it.
Thank you!
 Post subject: Re: Vapor lock
PostPosted: Thu Dec 31, 2020 5:37 pm
vapor lock in December? Not in this neck of the woods..... not sure where you are located.... but could it be something else?
PostPosted: Sat Jan 09, 2021 1:25 pm
Southern California, the gasoline was boiling in the carburetor and but I think I figured the issue. The motor was running 100% water in the cooling system
Users browsing this forum: No registered users and 137 guests
