It is currently Mon Nov 17, 2025 11:18 pm
 Post subject: Oil Pressure Tap?
PostPosted: Sat Aug 01, 2020 6:46 pm
Car Model: Sweptline D100
Hello All.
I would like to install a true oil pressure gauge on my 62 sweptline pickup with a 225.
I have the low pressure indictaor light in the dash. But would also like to have a true gauge to see exact readings. Is there a second tap into a oil galley to install a fitting for this. Or is there another way you would achieve this. I would like to keep the factory indicator light and just have a 2nd gauge.
Thanx.
Jim C.
 Post subject: Re: Oil Pressure Tap?
PostPosted: Sat Aug 01, 2020 7:26 pm
PostPosted: Sun Aug 02, 2020 10:55 am
Or check to see if the rear oil gallery boss is drilled & tapped.
Users browsing this forum: Bing [Bot] and 11 guests
