| Drop in Drilled / Slotted 5 on 4.5 10.87" Front Rotors https://mail.slantsix.org/forum/viewtopic.php?t=64790 |
| Author: | Greg Ondayko [ Wed Apr 22, 2020 2:30 pm ] |
| Post subject: | Drop in Drilled / Slotted 5 on 4.5 10.87" Front Rotors |
Drop in Drilled / Slotted 5 on 4.5" 10.87"Ø Front Rotors... Ignore the picture on the link.. https://www.summitracing.com/parts/bhi-05314-020 They look like this... Ignore the Long Studs.. I pressed those ones in... They come with normal stock type studs. ![]() ![]() So far so good for me on the '64 dart! Greg |
| Author: | drgonzo [ Wed Apr 22, 2020 3:50 pm ] |
| Post subject: | Re: Drop in Drilled / Sotted 5 on 4.5 10.87" Front Rotors |
So you just drilled your small pattern hubs to match and you have 4 piston brakes with 4.5 pattern? Or are these for the single piston brakes? |
| Author: | Greg Ondayko [ Wed Apr 22, 2020 4:09 pm ] |
No, this car has 4 on 4.5 rotors. F body spindles... single piston 73 up a body f body etc. Greg |
| Author: | drgonzo [ Wed Apr 22, 2020 4:10 pm ] |
Thanks Greg. |
| Author: | Badvert65 [ Wed Apr 22, 2020 4:14 pm ] |
Just curious, what does each rotor weigh? |
| Author: | Greg Ondayko [ Wed Apr 22, 2020 4:20 pm ] |
I didn't weigh them I would guess close to stock, but need to get a good scale to confirm. Greg |
