It is currently Mon Nov 17, 2025 11:08 pm
PostPosted: Sun Jun 07, 2020 12:50 pm
Just wanting some recommendations on strut rods and upper control arms for my 65 valiant, race car. I plan to replace the struts and the Upper control arms and will start looking for parts soon. I want to eliminate any binding and help the car with lift and weight transfer. So I figure I will go to a Heim joint style UCA and strut. Would you go with an aluminum strut? Any brand rcommendations? Same with the UCA recommendations?
Thanks! Rick
PostPosted: Sun Jun 07, 2020 3:07 pm
I bought heim joint end uca's for Grüne Hölle..
I got them from Reilly Motorsports.. RMS
Good parts.
I have stock stuff in Ruster.
Weight transfer is probably more in the shock tuning and rear springs and if you go to a stick things might be different still.
PostPosted: Sun Jun 07, 2020 4:48 pm
That is the ones I was looking at also. Heims have to help with free movement too.
Then it will be shocks... Then it will be springs.....Then and then..... :D :D
PostPosted: Mon Jun 08, 2020 11:16 am
Reilly makes excellent stuff. If they don't make UCAs any more, go to Firmfeel next.
You can get alum strut rods + heims (mancini?) and they are strong enough (even for my 64 Dart), but not super beefy. Actually, PM or email me because Mark C donated a set of alum struts to me and they are yours if you want them. Brand new.
PostPosted: Mon Jun 08, 2020 2:48 pm
RMS still shows adjustable (Heims) upper control arms for $349 a pair
PostPosted: Mon Jun 08, 2020 6:31 pm
Those should be the ones to get then!
Users browsing this forum: Ahrefs [Bot] and 6 guests
