It is currently Tue Nov 18, 2025 8:50 am
Do you want a dual clutch with new pocketed flywheel from Ram Clutches?
Poll ended at Tue Oct 06, 2020 2:06 pm
Aluminum Flywheel 26%  26%  [ 7 ]
Steel Flywheel 7%  7%  [ 2 ]
Organic Disc 30%  30%  [ 8 ]
Metallic Disc 4%  4%  [ 1 ]
23 spline 11%  11%  [ 3 ]
10 Spline 22%  22%  [ 6 ]
18 Spline 0%  0%  [ 0 ]
Total votes: 27
PostPosted: Sun Sep 06, 2020 2:06 pm
Car Model: 1964 Dart GT
Hoping to get as many as possible for this buy since Ram is very open to developing and manufacturing this clutch and flywheel for us. The price for 1 setup is $950. This will go down with more initial orders so if you want one, now is the time to get it.
What you get is a Ram Clutches Force 9.5 package consisting of:
A custom made pocketed flywheel, made of steel or aluminum, that will bolt to your slant six crankshaft. These will have the large center hole. Adapter rings are available for the smaller center hole cranks.
A double 9.5” disc, faced with organic material or metal, and an intermediate plate. Available in 23, 10 or 18 and likely other trans input shaft spline count.
A Force 9.5 pressure plate.
Please choose your:
Flywheel Material
Disc Material
Spline Count
